Replaced everything, still running hot!
Old 03-23-11, 01:21 PM
ES300Ride
ES300Ride's Avatar
Default Replaced everything, still running hot!
Hey All,
I own a 1992 ES300. It started running hot, so I replaced the radiator, but it still ran hot. Then I replaced the thermostat, water pump, and both radiator caps, and after each replacement, it is still running hot. I noticed the 100 amp master fuse had also blown, which I replaced also.
I noticed what looked like another radiator in front of the main one, and I'm not sure what that is, and if that can cause the engine to run hot, if damaged.
I could really, really use some help! Thanks everyone!
Old 03-23-11, 02:00 PM
JSM1284
JSM1284's Avatar
The other "radiator" is the AC Condensor. You should probabkly take the car to a mechanic. Could have blown head gasket. Is the coolant level still good? Is the fan operating properly? Is the condensor clogged, not allowing airflow to the radiator?
Old 03-23-11, 02:14 PM
BDSL
BDSL's Avatar
Air in the coolant line?
Was the thermostat installed properly?
Clogged coolant line?
Old 03-23-11, 02:21 PM
PFB
PFB's Avatar
Is the engine really overheating? Make sure that your temperature gauge, or the coolant temperature sensor are not giving you false readings.
Best thing to do at this point is to find a garage that has an IR (infra-Red) thermometer. It will determine the actual engine temperature, and help identify any blockages in the cooling sytem.
Also, how long does it take for the engine to overheat, and under what circumstances?
Phil
Old 03-23-11, 02:53 PM
BK4293
BK4293's Avatar
Plug on top of the powersteering pump, connector possibly unplugged itself. Reach your hand in there and feel around...
Old 03-24-11, 11:24 AM
brandoe91
brandoe91's Avatar
+1 happens a lot with the 2es
Old 03-28-11, 12:18 PM
ES300Ride
ES300Ride's Avatar
I wanted to update my status: My ES300 is no longer running hot. Hopefully I won't look too much like a nerd, but I was originally putting the coolant directly into the radiator, I then decided to put it into the water port on the engine. Viola! I'm not sure if that's how it's supposed to happen, but it's running fine now.
Thanks to everyone for your inputs! Totally appreciated!
Bocatrip
04-02-16 06:45 AM
T900RR
08-15-14 07:19 PM
Lexus082
Performance & Maintenance
11-27-07 01:31 PM
actuary
07-21-05 04:22 AM
Quick Reply: Replaced everything, still running hot!
