Tyres - Drop in pressure required?
Old 03-19-03, 04:51 PM
ychachad
ychachad's Avatar
Default Tyres - Drop in pressure required?
When one goes from a narrow tyre such as a 205 mm width, to a 225 mm width, it is obvious a drop in tyre pressure would be recommended. You just don't need that much air pressure. My question is, how much do you need to drop it by? Does anyone have a formula for this or some personal experiences? Thanks in advance.
Y. Chachad
Old 03-19-03, 05:04 PM
seanl
seanl's Avatar
The tire size doesn't have anything to do with the air pressure....naturally a bigger tire will hold more air at a given psi.
I run 235s on my LS400, 33psi front, 31 psi rear. Works for me.
32psi all around is ALWAYS a safe bet.
Old 03-20-03, 05:23 AM
ychachad
ychachad's Avatar
[QUOTE]Originally posted by selewis
[B]The tire size doesn't have anything to do with the air pressure....
Very, very untrue statement.
Old 03-20-03, 08:30 AM
seanl
seanl's Avatar
You are seriously overanalyzing this...
A 205 or a 225 is going to take the same air pressure, around 32psi, on an average passenger car. Granted a big rig 18 wheeler has different size tires than a car and probably takes different air pressures.
Both of my cars have approx 32psi in the tires, yet my Acura wears small 205/55/15s and the Lexus has 235/50/16s.
I'm not sure what kind of information you're looking for, but there's no calculations needed.
Old 03-20-03, 08:59 AM
tenpointed
Banned
tenpointed's Avatar
I have to agree with Selewis. Tire size doesn't matter for tire pressure. You can look at the side of the tire and it will tell you the maximum pressure for that tire. You should always put in the amount of air that Lexus recommends within 5 psi. Personally, I go with 38 psi front and rear, as recommended by my tire shop. Also remember to check your tire pressure every month because tire pressure changes 1 psi for every increase or decrease of 10 degrees farenh. Also rotate front to rear every 5-8k miles.
Old 03-22-03, 12:25 AM
97LS400
97LS400's Avatar
Check your glove box for the correct tire pressure settings. My 1997 LS400 said 29# normal and 32# maximum. Those pressures were lower than all my experience (10 year Honda Parts & Service manager) would indicate was right for a car this size but I dropped the pressure to 29# and the ride/handling improvement was amazing. Before the car was "busy" on the road and now it tracks to perfection. Mileage remains 22-23 mpg. Go with what Lexus recommends for your year and model!
sypw
02-19-16 08:03 PM
gebo
03-12-15 06:37 AM
my95tsi
05-12-11 07:26 PM
edinburger
10-25-09 07:11 PM
Flipsonic
09-24-06 09:59 PM
Quick Reply: Tyres - Drop in pressure required?
