CODE 31 Help
Old 03-19-15, 01:52 PM
JosB
JosB's Avatar
Default CODE 31 Help
Engine light went on so i checked the code. 31 is mass airflow sensor. So i replaced the sensor. It ran good after the installation, but after a day it went back to the way it ran before the installation. The engine light N trac light are back on also. People are saying its the ECU. Wanting some opinions on the matter
Old 03-19-15, 07:01 PM
timmy0tool
timmy0tool's Avatar
always note the year of your car pls!
Old 03-20-15, 04:42 AM
JosB
JosB's Avatar
Sorry its a1994
Old 03-20-15, 09:13 AM
Legender
Legender's Avatar
Where did you get your sensor from? New or used? These are the type you can't clean.
Those connectors are prone to break with age and miles. Are you sure the connector is on tight and has a good connection? Did you clean it with electronics cleaner?
Old 03-20-15, 11:12 AM
JosB
JosB's Avatar
Originally Posted by Legender
Where did you get your sensor from? New or used? These are the type you can't clean. Those connectors are prone to break with age and miles. Are you sure the connector is on tight and has a good connection? Did you clean it with electronics cleaner?
I got it used. But said it was tested to work.
Yeah everything is tight N i cleaned out both sides of the plug.
Old 03-20-15, 11:31 AM
RA40
Super Moderator
RA40's Avatar
A past thread and there are other discussions on Code 31 that may be useful on other Club Lexus sections.
These from the LS area:
https://www.clublexus.com/forums/ls4...-ecu-good.html
https://www.clublexus.com/forums/mai...em-solved.html
Srinivasak
RX - 1st Gen (1999-2003)
19
10-20-19 03:54 PM
Crossxup11
06-19-19 07:04 AM
Seadaddy
01-22-17 07:27 PM
kaliboy562
03-26-14 08:22 AM
Quick Reply: CODE 31 Help
