ECM ECU Repair shops
Old 07-08-14, 10:19 AM
darimura
darimura's Avatar
Default ECM ECU Repair shops
I am in the process ofsending out my 91 LS 400 ECM/ECU to be repaired, when I google the repair shops and speak to them I get a wide varying price for the repair, can anyone recommend a specific shop?
thanks in advance.
Dave
Old 07-08-14, 11:58 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
usually TV repair folks can do it, but they are few and far in between. where in cali are you from? socal or norcal?
Old 07-08-14, 12:04 PM
darimura
darimura's Avatar
SoCal/ Ventura County/ 805
Old 07-08-14, 12:13 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
are you providing the appropriate capacitors to them already? or you are looking for them to provide the caps for you. i suggest you source the caps yourself using the mother thread to get the exact quantity and model, then find the appropriate shop.
i don't know any shop around your area but look for electronics service technicians who do PCB soldering and repair. better if you can find those who specialize in surface mount soldering although the caps are basic through-hole soldering. if they surface mount, they tend to be more experienced with sensitive electronics like your ECU!
Old 07-08-14, 12:18 PM
darimura
darimura's Avatar
I do not have the parts so I need someone to do the whole thing, also I was thinking that a TV guy would not be able to test the ECM before and after his work.
Old 07-08-14, 12:25 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
go to digikey.com and order the caps as indicated in the thread here, keeping in mind of the year of your car.
https://www.clublexus.com/forums/ls4...capacitor.html
there is no way to test the ECU when off the car. there is a ripple test in the thread but if you don't understand car electronics too well it may be well over your head.
order the caps and have a professional install them.
Old 07-08-14, 12:43 PM
OKSTANCE
OKSTANCE's Avatar
ordering those caps from digikey is totally a guessing game if you dont know what youre looking at
Old 07-08-14, 01:12 PM
darimura
darimura's Avatar
I found a website: ecurepairnow.com he said he could repair my ECM for $175.00 with a one year unlimited miles warranty. what do you guys think?
Old 07-08-14, 04:48 PM
Caniac14
Caniac14's Avatar
In the very first post all available caps needed are listed and linked. All you have to do is click the links and add to cart. Even if you leave the site your cart stays. That's how I did it. And I saw you posted a question in a different thread about not having the exact caps your car called for. If they don't have the exact voltage your car calls for a higher voltage cap is ok.
Old 07-09-14, 02:31 PM
OKSTANCE
OKSTANCE's Avatar
oh okay because the voltage numbers didnt match up with the ones listed that i am SUPPOSED to order
Old 07-10-14, 01:00 PM
mattylex77
mattylex77's Avatar
For all your Lexus Electronic needs call Darryl Geller (404-550-7511) Darryl is a pro and super helpful, also works with Lexus of Atlanta. Tell him Matt sent you
Old 07-11-14, 08:15 PM
python
python's Avatar
I have sent a ecm to Darryl..it was for a 94 camry..worked fine after his repair.
bmatic01
01-06-16 02:41 AM
petebrown
03-09-14 06:14 PM
SW2UZ
CL of Southern California
07-09-13 08:19 PM
driverJM
03-30-11 08:26 PM
gaijin
12-21-05 08:37 PM
Quick Reply: ECM ECU Repair shops
