1994 ls 400
1994 ls 400
Afternoon, we took our 400 into the shop for a state inspection. Same shop that traditionally does all of our work. Good mechanic, uses common sence. The 400 just turned 200K miles.
We have had a nagging problems with several things and the mechanic said that it's to the point where there are fearful to pass it any longer due to the following...they recomended that we get rid of it and get something else to drive. Issues...1) the driver power window switch only works when you pull the "trigger" back right...then it may go up...goes down fine, 2) heater doesn't always blow warm air...coolant level is ok though, 3) truck panel night light bulb socket has been singed and doesn't work, 4) power steering pump leaks onto alternator and all three of its hoses need replacing, and 5) idle vacuum switch needs replacing. Mechanic felt that the costs for all of the above is far more than the car is worth.
Thoughts?
Thoughts?
Have great fix idea!
LOL... Sell it to me... cheap!
On a more serious note, wait a few hours till LSCowboyLS logs on. He's very knowledgable about all these LS400 issues and more than likely can suggest ways to fix most, if not all the problems. I know for a fact, after reading a few of his posts, that the power steering fluid leak is very common on all 90's LS and more than likely a simple O-ring replacement. I just bought a 94 SL myself about 6 weeks ago. Have had to cap off steering fluid 3 times now. Am going to replace O-ring this weekend.
Another common problem with this vehicle is leaky capacitors on the ECU board which causes all kinds of mayham... possibly even some of your issues. Again, I'm new to this, Cowboy usually answers post questions like yours most every evening. I'm sure he'll have some good tips for you. Hope that they are small, fixable issues... these are awesome rides that you should enjoy well into 400k mile territory.
Good luck,
Sammy
Good luck,
Sammy
Wow I guess that mechanic only likes to do inspections and work on cars that they are familiar with.... Everything you mentioned has been well documented on these forums. most notably the power steering leak. Do a little reading and ask some questions and you will be amazed. Make sure to buy ALL your parts online besides the stuff that you can most likely get at the junk yard.
the power steering leak may be nothing more than the $3 o-ring between the reservoir and pump - just because hoses are wet with fluid, doesn't mean they are leaking - in any case, fix that problem before all others, regardless of where the leaks are, because it WILL quickly kill your alternator (I killed mine!)
by the way, there are high pressure PS hoses (all 3, which is really just 1 really large long hose) for all of $26 on ebay, so even if "all 3 high pressure hose sections" were leaking, AND the o-ring, you are looking at a whopping $30 in parts - tell that mechanic to go take a long walk on a short pier!
Thanks to everyone for the wealth of information. Questions: Will the red radiator fluid help...and whats the benefit over traditional antifreeze? 2) where is the best sites to find parts online and how can I make sure that the 0 rings I see are extactly whats needed, and 3) does anyone know if there are any actual links on this forum to photos or videos that show how to repair?
Sorry for all of the novice questions...just that I am used to working on my old dodge trucks and have never explored in the world of the wife's ride......Lexus
Appreciate the help
Appreciate the help
it is marked 44362A in the photo below:
Funny... here in TX none of those things would have been looked at during a state inspection, Horn, brakes, wipers, lights and no CEL on are the big things. Surprised they to into such depths in VA...
And while it appears things are adding up, with the help of this sight those issues can easily be dealt with.
If you like the car, enjoy the ride, and love saving money then put a few hundred into it and avoid having to make car payments and paying higher insurance.
and lexls.com has some good video tutorials for this car.
What part of VA are you in. I'm parting out my 93 ls400 at this very moment. (keeping the engine and trans).
My window switch works fine and I have the light harness.
BTW I'm in Richmond.
