Weir Oil leak Hoping to Find source Pics attached
It stared leaking a While ago I am unsure Of where it comes from. don't really have any issues with the car it just leaks and wanna see if i need new differential or just need to send this one to the grave yard. I dripping From thought it was engine oil dripping from valve covers but on to the manifold but it wasn't . so any help is great
are you even sure it's oil?
have you looked at it on a white coffee filter to see the real color? - tasted it?
it could also be coolant (sweet tasting) or transmission fluid or power steering fluid (both red or reddish brown or purple)
its oil felt it not coolant or anything. powesteenig pump is broke and no fluiid there for a couple of years and felt around transmission but dont feel any oil
Kinda Difficult to tell whats what from the pictures due to the close proximity of the shots. The first and last pictures, is that the Shaft coupler just behind the Transmission?
IIRC the only seal in that area is the transmission rear oil seal, if the leaking liquid looks a red/brown color it would confirm this to be the cause.
Seal is on far right in diagram.
you still need to verify if it is transmission fluid or P/S fluid (also trans. fluid) or oil, get some on a white coffee filter and look at in under good light
zrooster99
RX - 1st Gen (1999-2003)
03-08-18 08:55 AM
