Neutral saftey switch bypass?
What needs to be done to bypass the neutral safety switch on my 93? I've searched and only found a FEW things but they were for the SC's. I cant find any info on the LS platform. Any help would be greatly appreciated!
I plan on eventually wiring into the clutch so it wont start without the clutch engaged but for now I just need to bypass it so she will start up and run.
https://www.clublexus.com/forums/per...o-crank-2.html
i did this to my 92 SC400. should be the same for LS400 since i had a LS tranny in my SC. that was just temporary i solder, heat shrink and ran some wires to the clutch switch.
Ok just for future reference if anybody needs it. Before jumping 5 and 6 in the diagram above my car did not start. I put a 10amp fuse in 5 and 6 and she fired right up like normal. So yes all you need to do is jump the two together. I'll be cutting these and routing them up to the clutch pedal soon.
JspecSC3
Performance & Maintenance
03-10-06 05:28 PM
