radiator fans
Old 10-27-13, 02:52 PM
msweber97
msweber97's Avatar
Default radiator fans
as soon as the car is started both fans seem to run constant is this normal even when the car is cold?
Old 10-27-13, 03:04 PM
LScowboyLS
LScowboyLS's Avatar
what year and model of Lexus?
Old 10-27-13, 03:22 PM
msweber97
msweber97's Avatar
it is a 93 ls400
Old 10-27-13, 03:53 PM
Tatty93LS
Tatty93LS's Avatar
The clutch fan will rotate/"run" when the car is cold. Otherwise, if you here electrical fans, it's most likely the AC fans running. These, to my knowledge, should not run unless the engine is warm and the AC is on.
Old 10-27-13, 04:14 PM
LScowboyLS
LScowboyLS's Avatar
check the electric fan coolant temp sensor in the bottom corner of the radiator, it is likely shot
Old 10-27-13, 04:43 PM
msweber97
msweber97's Avatar
thats what i was figuring a coolant temp sensor, ill look to see how to check it when i get a chance thanks!
soundquest
06-11-19 11:38 PM
Dvinhie
06-30-14 10:10 PM
Avster
RX - 1st Gen (1999-2003)
09-04-13 03:21 PM
ivnnln
08-26-10 04:29 PM
habdelr
GS - 1st Gen (1993-1997)
13
10-03-07 11:12 AM
Quick Reply: radiator fans
