AT fluids - best test I have seen so far:
If you like researching AT fluids, than this test is for you. It is quite an eye opener (try and guess which ATF won):
http://www.goodsenseoil.com/G2457-GearOilWhitePaper.pdf
Seems that I will be changing my ATF yet again; I have redline synthetic ATF in there right now, and it is great for my purposes, but there are better ones out there. It scored great in some tests such as cold but not too cold performance as well as pressure tests, but failed in some others...
Are you going to use the Amsoil gear oil for your AT?
I don't understand your point. This looks like just an advertisement of Amsoil gear oil.
Exactly! - especially when our Aisin transmissions last far longer than any other transmissions, using the T-IV fluid they recommend, why would you deviate from that kind of track record?
Well maybe I will use that one as differential oil, but I was excited to find out that AMSOIL seems to go way out of their way to make a good oil... I know it sounds like a propaganda piece for AMSOIL, but apparently it is all well documented and done independently.
Not that I have a horse in this race, just trying to see what is out there.
Here is one about their ATF:
http://blogs.moparmusclemagazine.com...isison-fluids/
and this:
http://www.amsoil.com/shop/by-produc...ont%2fatf.aspx
but why would you assume that the test is an advertisement for Amsoil? Maybe they really know what they are doing when it comes to oils?
BahHumBug
amsoil is notorious for hiring companies to do "independent" comparisons.
some of the nice folks at BITOG forums have actually done 3rd party consumer testing and gotten clean results. I suggest you look there.
Redline synth gear oil is actually what I find most people with manual transmission japanese cars running. (esp. supra/mr2/240/FC crowds.)
Funny enough, I already have redline in my AT, and was thinking of dumping it after reading AMSOIL tests...
In the end, it seems that either I can spend an eternity trying to get to the bottom of it all, or just stick with Toyota/OEM stuff.
BahHumBug
I guess when something sounds too good to be true...
tyoung88
GX - 1st Gen (2003-2009)
01-28-08 05:42 PM
