squeak from left front tire?
Old 05-07-13, 05:07 AM
joshbaesl
joshbaesl's Avatar
Default squeak from left front tire?
I just replaced my steering rack andnow somewhere by my left front tire a continous squeak happens. my car wants to vear to the left pretty bad but i believe i need an alignment. any thoughts? please help.
Old 05-07-13, 11:55 AM
timmy0tool
timmy0tool's Avatar
could be many things but i would start with the alignment first. make sure your lugnuts are tight as well as all the bolts you touched during the rack change.
Old 05-07-13, 12:23 PM
djsurfer
djsurfer's Avatar
Yes like Timmy stated it could be many things, I had a continuous squeak aswell that I didn't know what was, first I lifted the car to see if wheel was rubbing on anything, and nothing. Then checked the discs for signs of warpage and scratching of surface and nothing, then I went ahead and lifted the car one more time and put it on drive and saw the rear wheel was wobbling a bit, sure enough the squeak coming from my wheel was actually from the wheel bearing since slamming the car. Could be your issue but do all the checks I did and Im sure youll find your issue. Good luck!!! Hopefully its not your wheel bearing, if it is, I suggest you might aswell replace those as the other one will also get shot too and last thing youll want is losing a wheel on the hwy at 80mph. Trust me its happened to me, not the business.
Old 05-07-13, 09:20 PM
YoshiMan
YoshiMan's Avatar
If you replaced the whole rack, or even just unbolted the old one, you really NEED to get an alignment done! I did suspension/steering work on my brothers car once, and it did a similar thing. He chose not to get it aligned and within a few days he had burned both of the front tires down the the threads.
whatnext
11-05-14 05:27 AM
kennyD
02-12-14 06:17 PM
hms09
11-15-12 09:49 AM
IS_Sunny
Suspension and Brakes
09-07-07 11:55 AM
Ex996
12-05-02 07:11 PM
Quick Reply: squeak from left front tire?
