LS400 Low tach idle & check engine light
Old 05-05-13, 03:43 PM
daveskates
daveskates's Avatar
Default LS400 Low tach idle & check engine light
So I purchased an 90' LS400 not too long ago, has about 220k miles on it, drove it home from the guy's house and it was a bit of a drive. He told me the temps do rise over time because there is a crack in the coolant resevoir tank (which I need to find one). Wasn't sure if they were year specific but mine is a 1990. Also it has a check engine light BUT as i drove it the only thing I really noticed was it had a low idle when I was sitting at a red light. I wanted to know what type of scanner do I need to check and see what code it's throwing? Is it OBD 1 or OBD 2?? I would really like to get it figured out so I can start driving the car around already
any help would be very much appreciated, thanks !
Old 05-06-13, 12:10 AM
LScowboyLS
LScowboyLS's Avatar
no scanner needed - here is how you read the codes
Old 05-06-13, 12:34 PM
daveskates
daveskates's Avatar
wow thanks !
i assumed I had to go out and buy a scanner, i hope the check engine light isn't too serious the car runs fine for the most part
Old 05-06-13, 01:27 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
OBDII did not get introduced to the LS400 until the 95-up models, so you don't need a scanner for cars before that model date.
Old 05-27-13, 10:29 AM
daveskates
daveskates's Avatar
thanks
LexuBarge
01-13-19 09:44 PM
Lnmarlow
16
01-24-18 04:06 AM
mrrbearxd
10-03-13 06:20 PM
dma251
03-20-10 12:51 PM
BULL3T
01-18-03 02:54 PM
Quick Reply: LS400 Low tach idle & check engine light
