Another Tranny Mount Question
I understand that this appears to be a pretty straight-forward thing for the DIY'er. (apparently lots of bolts to remove!) but I'm trying to find out if there are any exact visuals/pics on how to do this repair. Sorry if this has been asked before, but I didn't find it while doing a search, though hopefully I overlooked it. Thanks as always!
Unbolt the aluminum bracket from the chassis then the mount should be connected to that and the trans unless the mount is bad bad and separates. un bolt it from the trans or bracket.. You'll figure it out.
Its like legos. Just pay attention and remember how it came apart.
Simple aid to help trans mount R/R
Blue is connected to trans (4 bolts)
Green is mount to bracket (4 nuts)
Red is connected to chassis (4 bolts)
The colors correspond with location on the bracket. If you can't figure this out... Highfive! good luck!
The pan can take the weight spread out. Most cars do.
part number pictured, upon unbolting the old one separated!
comparison
vibrations did minimize but are not completely eliminated. next is to save up and do the motor mounts.
TLsc300
Performance & Maintenance
06-11-12 06:11 PM
