P0336 code
P0336 code
I've been having this code keep popping up(keep clearing with a cheap scan tool but it comes back after 2 or 3 starts). It's for the crank position sensor. I've replaced the sensor twice now. It runs perfectly fine, accelerates as it should, idles well, no misfires or anything. The harness is covered with a wire loom but from what I can see there's no damaged wires. Does anyone know which pins the crank sensor is on the ecu? There isn't relearn process for it is there?
EDIT: Nevermind. Found the diagram on Lextreme. Going to test the harness for a short.
Bobster999
RX - 1st Gen (1999-2003)
265
12-12-23 02:02 PM
Rbeeber
12-02-18 08:42 PM
