All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
#811
Changed the ECT, broke the plastic clip, so this is next, but I won't be doing it - excited to see how both of these combined will improve upone an already smooth and powerfull ride for a car with 231,000 miles on it. If anyone knows of a resource in Colorado to do the soldering, I'd appreciate it. And I ordered the exact caps from the sources supplied in this thread, thanks for the detailed information, just wish I had more than an 8th grade level of soldering experience!
#812
Thats where Im at!
& stay away from ecmtogo.com
#814
Just spoke with Darryl at lexuspartsplus.com about fixing the ECU. Seems legit... What do you think LScowboyLS?
http://phoenix.craigslist.org/nph/ptd/4432235192.html
#816
Hi all,
Just read all 55 pages and signed up.
What a handy thread.
I have a late 97 5 speed VVTI LS 400 that I bought here in Australia three years ago and has 350,000 kilometres on the clock with the following symptoms.
-"Check engine" light comes on minutes after starting up.
-"VSC off" light comes on as well.
- The engine goes into "Limp Home" mode and I need to shift gears manually in order to get up hills, even fairly minor ones.
- The exhaust smells a bit strange.
- It runs fine for a while and things then go pear shaped. I used to get 10 minutes of normal operation. Now its more like two.
- Ive noticed that the "mode" readout sometimes changes from current usage to another mode.
- Ive noticed too that the brakes seem to lack the grip I'm used to.
I will order the caps as per updated info at post #1 for the "98 - 00" series.
I'll probably get a mate who is a computer guy to do the soldering.
I'm not totally sure where I'll find the ECU. I know I've changed the air conditioner filter down there before so I'll poke around and see what I find.
One question that I haven't seen raised yet that the more informed Lexus owners may have an answer to.
Are there any other mods that might be worth doing while I have the ECU out and an experienced solderer at my disposal.
Regards
Regards
#818
Regards
Regards
There are some mods or improvements such as a stable operation at the lower +B voltage, the gas-mileage improvement and others but I am still doing experiments and I dare not release those open yet. What I don't like is that there comes too many questions to my personal mail box when I write some. I seldom can respond those.
May be I can open this. The photo below shows a dis-colored resistor at a DC regulator. Compare the color between the one with a purple arrow at the upper part and the one at the lower part with an yellow arrow. The lower one is a 2.7 ohm resistor. This tends to increase the resistance resulting a poor engine behavior especially at a cold snowy night or a foggy summer night with almost every electrical equipment on. The voltage regulation becomes poorer at those times when the resistance is increased. You'd better to replace it if the resistance is bigger than +15%.
#819
Quote: "I'm not totally sure where I'll find the ECU."
Hi Bunnybob.and welcome.
I've a 1999 R/H/D model and I wonder about the location of the ECU, too. I've got the American/Canadian repair manuals as the Australian manuals are no longer available. The L/H/D models have the main ECU on the right according to the L/H/D books I have and I 'suspect' that the R/H/D models have the ECU on the left.
I think that your brake issues might be non related to ECU issues. Someone more knowledgeable here can tell you for sure.
#820
Hi Yamae,
Parden my ignorance, but I don't know what you mean by "read codes first".
If this has been covered in the thread previously, I'd like to know where. I'm happy to do the research but am not sure where to start.
Is there some form of self diagnostics. My car has been trouble free since I bought it so I'm new to this.
Mine is right hand drive, like Kevvos.
My guess is the brake issue is related to the VSC being off.
#822
The ECU has a capability to diagnose the car and tells the driver what is(are) wrong showing him/her the code(s) at the multi display located under the speedometer as long as it is working well. The detail is in the manual in case of a JDM. It must be found somewhere at this forum too but I don't remember where it is. Dealers have a scan tool and you can ask them to diagnose the car using it but they may charge you some money.
The ECU is located close to the blower unit where you put the cabin filter in. A JDM RHD Celsior has it 6-7cm away left from the blower unit. May be yours is located at the same place.
#823
All are written in Japanese but you can see how the diagnosis can be done at the middle part of the page of below link. The Google translation might help you some. Access the page below and double click each photos and this will let you see bigger photos.
http://celsiorup.com/custom20/2099RadarCruise4.htm
I just pick up the related area and show you the screen shot.
