94 LS400 #1 ignition coil
09-01-12, 10:15 PM
Is there an easy way or trick to replacing the #1 ignition coil on my 94 LS400 ???? not much room to get at it
09-02-12, 12:53 AM
its not really hard, just a tight space. Removing the battery should give you some space to work.
09-04-12, 05:41 PM
Remove the battery then remove the bracket that its screw on after that its self explanatory
09-05-12, 10:11 AM
you dont have to remove thew bracket. just remove the battery and use a short phillips screw driver or a phillips socket on the 4 scews.
iSuxeL
11-29-15 05:29 AM
LScowboyLS
24
04-05-14 02:27 PM
AzHotLS
11-30-09 06:44 AM
jjloose
01-04-07 03:48 PM
RKJ
05-23-03 03:33 PM
1 ,
1994 ,
94 ,
change ,
check ,
coil ,
connector ,
cost ,
ignition ,
ingition ,
lexus ,
ls400 ,
remove ,
replace ,
replacement
