Confirmation on this part please?
Old 07-26-12, 10:38 PM
Shiryo
Shiryo's Avatar
Default Confirmation on this part please?
One of the rear driver's side arms are bent and i'm not sure exactly which one it is... The car was in a shop and I only briefly got to check it, so I don't remember.
Is this the correct part circled?
Old 07-27-12, 04:39 AM
billydpowe
billydpowe's Avatar
are we supposed to be guessing with you??
I guess I just dont understand.
Old 07-27-12, 05:16 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
given that the arm in the picture you took has an eye-style end, and th eone you circled has a stud, i doubt they're the same....
you need to zoom out and take a better picture.
Old 07-27-12, 06:41 AM
LSTex
LSTex's Avatar
That appears to be the right part, but it's difficult to tell without a view of the other end. From that angle, both the picture and illustration have the eye style end (the orientation in the illustration is backwards from the picture). Taking another picture from the other end would be helpful.
An item of interest is what appears to be another bracket in the center of the rod pointing upwards on the illustration. That part is absent from the picture. I'd suggest taking the picture and illustration to your local auto parts store and asking them, just to be sure.
Old 07-27-12, 08:26 PM
Shiryo
Shiryo's Avatar
It's not my LS... I dont have access to the car, all I got... The mechanic showed us on AllData that the arm in question is Number 1 or something. Sewell shows it as that one, but like you pointed out LSTex... It doesn't look like it 100%.
The right of the picture is the front of the car with the left of the picture being the rear. So this arm is forward of the axle. Was hoping someone could verify if the part circled on the diagram is the arm that is forward of the axle...
Old 07-27-12, 09:16 PM
Shiryo
Shiryo's Avatar
He brought the car over and we checked it out. Here's another pic. I believe I circled the right one since it has a ball joint on the end. The diagram just places them weird...
Old 07-27-12, 10:47 PM
LSTex
LSTex's Avatar
I think you're right, Shiryo. The one you circled looks like the only one on the diagram that could possibly match the picture. The arm below it in the picture also matches the arm below it in the diagram, so that's more confirmation. The missing bracket bothers me a little, but I'm about 90% confident that you have the right one.
Old 07-27-12, 10:55 PM
Shiryo
Shiryo's Avatar
Yeah, that missing bracket bothers me too... Running around on eBay, a lot of the auctions say they are interchangable on both sides... Wonder if this is true.
Old 07-28-12, 11:57 PM
upgrade
upgrade's Avatar
Thats your toe link. The part circled in the diagram is the same as the one in the picture. That part can be pricey new.
Old 07-29-12, 12:28 AM
Shiryo
Shiryo's Avatar
$100 from sewell. Posted up in the classifieds for one, hopefully someone chimes in...
Now that you mention it being the toe link... Would that bend be the cause of bad camber? The car has some massive negative camber as it is cruising. Guess we'll find out after it's replaced and aligned.
Old 07-29-12, 12:56 AM
upgrade
upgrade's Avatar
That bend is affecting toe not camber. Camber is adjustable on the LS400. Your tech should be able to get it back in spec as long as something else like the upper & or LCA isnt bent as well.
Old 07-29-12, 04:15 AM
LexusPartz
LexusPartz's Avatar
Yes, the picture and the selected part are correct. It is the toe adjusting arm, I would suggest also getting the cam and eccentric as well. If they are frozen in pace the tech is going to torch them off.
Old 07-30-12, 04:00 PM
Shiryo
Shiryo's Avatar
Would you happen to have part numbers on those parts? We're just looking to get the car sitting straight, seems to sit really crooked when driving. Also, when we looked at it up on a lift, both the rear and front wheels were sitting about an inch or so higher than the passenger side. Seems like a accident car, but we can't find any frame damage.
HBcubs
01-22-08 08:07 PM
Gojirra99
01-01-08 10:19 PM
xcntuatd77
ES - 5th Gen (2007-2012)
23
05-01-06 05:52 PM
blanklooks
06-29-02 10:32 PM
Quick Reply: Confirmation on this part please?
