1995 LS400 PO135 code bank 1 sensor 1...help
Old 07-05-12, 12:45 PM
yanivsme
yanivsme's Avatar
Default 1995 LS400 PO135 code bank 1 sensor 1...help
95 LS400 107k miles
I just found out that I need to replace this sensor (as the 1st step) to solving this issue.
I would like to do it myslef. I did a search and found a little info but Im wondering if anybody here with an LS has had this issue. I know it is on the drivers side and I need a special tool for it.
Pictures?
Instructions?
Where to buy OEM part?
Thanks in advance.
Old 07-05-12, 02:40 PM
Lavrishevo
Lavrishevo's Avatar
http://us.lexusownersclub.com/forums...howtopic=32035
Replace pre-cat 02 sensor on driver side I believe. Bank one and two refer to firing order. So if the first to fire is drivers side then that is bank one.
Rockauto.com has OEM for pretty good prices.
Old 07-05-12, 11:56 PM
yanivsme
yanivsme's Avatar
Thank you. I'll give it a try, I just hope I can get to it...I was actually told to do it from the bottom?
jwigley
RX - 1st Gen (1999-2003)
10-13-15 09:54 AM
Sanpete
14
12-18-14 02:07 PM
SilverJade
11-24-13 06:32 AM
vnskippy
03-13-10 12:32 PM
slash
03-05-05 05:48 AM
Quick Reply: 1995 LS400 PO135 code bank 1 sensor 1...help
