2jz swap engine mounts
Old 05-31-12, 08:13 PM
AGD3000
AGD3000's Avatar
Default 2jz swap engine mounts
Hi, I've just bought a LS400 and interested to do a 2jz-gte swap as the engine has done almost 210,000 miles.
I've been reading up on the 2jz swaps and it seems I need to use the later model or JZS161 Toyota Aristo/GS300 2JZ VVTI engine mounts?
Can I confirm this is correct? Thanks.
Old 06-01-12, 06:39 AM
3UZFTE
3UZFTE's Avatar
I can confirm this. I have also seen custom mounts, but if you looking to keep it factory, those are the first choice for swappers. Good luck, keep us updated on the swap.
Old 04-15-13, 03:04 PM
taurus45
10th Gear
taurus45's Avatar
Did you have part numbers for these by chance?
Robles84
10-21-19 08:37 AM
ca18det
03-23-12 09:24 AM
vertexsc
Performance & Maintenance
04-26-06 12:18 PM
bmsport
06-18-03 01:36 PM
Quick Reply: 2jz swap engine mounts
