91 LS400 Instrument Cluster or Sensors?
Old 05-01-12, 01:51 PM
paulwall86
paulwall86's Avatar
Default 91 LS400 Instrument Cluster or Sensors?
When I open the door I do not get an indicator light saying my door is open is that normal? I however do get a light when I turn off my overdrive and my power switch next to my shifter. Any ideas?
Old 05-01-12, 01:53 PM
timmy0tool
timmy0tool's Avatar
there should always be an indicator light in the cluster showing a door open, at least on my 97 it does. im not too sure about the 91s. check the ground pin which hits the door as you close it. is it corroded? rubber torn? does this happen on all doors, or only the driver?
Old 05-01-12, 02:59 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
door switch is probably dead.
Old 05-01-12, 06:30 PM
mikes7ke
mikes7ke's Avatar
I think it's called the courtesy light switch. If that's al it is it's an easy fix.
biglagoon9
09-05-22 07:51 PM
JuiceIam
Performance & Maintenance
04-27-17 04:08 AM
Deegee
17
02-16-17 07:57 PM
koufax3232
01-29-14 04:10 PM
redzeppelin
08-09-05 11:50 AM
Quick Reply: 91 LS400 Instrument Cluster or Sensors?
