Rear Seat Arm Rest Question
Old 04-16-12, 07:19 PM
johnnyg66
johnnyg66's Avatar
Default Rear Seat Arm Rest Question
What are the odds a rear center arm rest from a 95 will bolt in and fit a 92?
Only asking because a 95 has cup holders and early ones do not.
Thanks.
Old 04-17-12, 05:47 PM
johnnyg66
johnnyg66's Avatar
Okay how about this. Anyone willing to take good measurements of there rear seat center arm rest from a 95 or 96 whichever has a cup holder. And post them here and maybe a good photo of it and how it bolts on. Hope someone can help.
Thanks in advance.
Old 04-17-12, 07:04 PM
Kansas
Kansas's Avatar
It's been nine years since I sold the 1990 LS that used to by parked in the garage by my 2000 LS but my memory is that the rear armrests in the two cars were of a very different size and proportion. I think the rear seat and armrest in the 95-00 LS are all essentially the same except for the center headrest in the 98-00.
You could buy one of those cupholder thingies that sit on the transmission hump or fab one like other have done.
Attached Thumbnails Rear Seat Arm Rest Question-1992-vs-1995-ls400-rear-armrest.jpg
Old 04-17-12, 08:53 PM
johnnyg66
johnnyg66's Avatar
Thank you Sir.
It seems very close my guess we are talking a inch or so. The brackets look the same all the other info i could find seem to say so. Not sure if i want to buy the used one or not. Hoping someone will still take measurements of one.
Old 04-18-12, 04:00 AM
Kansas
Kansas's Avatar
The rear armrest of my 2000 LS400 (approximate - within 1/4 inch): 18 1/2 inches long x 9 1/2 inches wide x 4 1/2 inches tall.
It seems quite a bit wider than the one in the 90 LS I had but everything inside my 00 LS seems bigger than in the 90 LS. The 95-00 interior seem huge compared to the 90-94 ... 2 1/2 inches more rear legroom, slightly wider in the back and a little more headroom - something I noticed a lot as I switched back and forth between the 90 and the 00.
Old 04-18-12, 05:55 AM
johnnyg66
johnnyg66's Avatar
Thanks again,
True that model is roomier than the early ones. I compared the sizes. Other than the 92 on being tapper on front end and it does become a bit narrower. The sizes are not that far apart. I thinking a later model would be a tight fit or best left down. So in may pull the trigger and get the used one. Cost of a new one from lexus is about a grand.
Thanks again.
Old 04-18-12, 07:25 AM
ocr
ocr's Avatar
just build a table in the center. itll look classy and be functional as an arm rest and a cup holder. you can also incorperate other features as well if you want. like whrn i get around to building one, im going to include a small door that will hide a standerd house power outlet for people to plug in laptops and other stuff.
Old 04-18-12, 10:16 AM
johnnyg66
johnnyg66's Avatar
If i was any good at wood work i might do that. You will have to do and share the photos.
There might be some aftermarket or other pre-made tables that could fit.
Old 04-20-12, 01:56 PM
Boomer9094
Boomer9094's Avatar
Ok, I have an extra 95 rear seat back.
Old 04-20-12, 01:58 PM
Boomer9094
Boomer9094's Avatar
the part numbers are the same but I do not know if they are the same size. I like the cup holders. use them every day. I leave the front ones closed.
Old 04-20-12, 06:32 PM
johnnyg66
johnnyg66's Avatar
I got my used one in and will try to install it this weekend.
Old 04-21-12, 10:02 AM
ocr
ocr's Avatar
I have yet to see one.. unless I overlooked it. I can build one mainly cuz my gramps has a full wood working shop. I'm probaly gona make a cardbord ruff draft so I can get measurments and go from there. I just have no idea how people are mounting there front tables, unless they are just seting it on the open glove box.. and I don't like that idea. When I build my front table, I want it to be secure and mostly perminant
Old 04-21-12, 01:35 PM
johnnyg66
johnnyg66's Avatar
Okay here it is. Just a bit shorter than original and wider so sticks out a little. The gray color is lighter just some too.
Attached Thumbnails Rear Seat Arm Rest Question-img-20120421-00008.jpg   Rear Seat Arm Rest Question-img-20120421-00009.jpg
Old 04-21-12, 01:46 PM
ocr
ocr's Avatar
Just keep it down.. looks good by the way.!
Johnny520
RC F (2015-present)
06-25-17 05:24 PM
gianttama
RX - 3rd Gen (2010-2015)
03-07-15 09:26 AM
istarzan
04-20-14 09:00 PM
ayan01
07-27-10 08:20 PM
Quick Reply: Rear Seat Arm Rest Question
