EBC Red Pads install question
Old 03-22-12, 08:01 PM
maximus54
maximus54's Avatar
Default EBC Red Pads install question
I just got a set of LS400 4 piston calipers, but they did not come with any pads. I have the brake fit kit (Springs and "T"/"X" piece) and EBC Red stuff pads for them, but when I look at the diagrams I am missing the spacers that go on the pad. On my GS the pad has little notches that those spacers hook onto. But on these EBC pads there aren't any notches for that. Do i need to have those spacers?
Old 03-22-12, 09:32 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
they're called shims, and yes you need them otherwise they'll squeak.
Old 03-23-12, 04:14 AM
VanCityLS4
VanCityLS4's Avatar
Any feedback on how good/bad the EBC pads work on the UFC20 ?
Old 03-23-12, 05:18 AM
maximus54
maximus54's Avatar
The pads have built in shims, but the pieces I'm talking about look like little hooks that attach the bottom of the pad, they are called spacers in the brake diagram posted in the diy section.
Old 03-24-12, 03:35 PM
maximus54
maximus54's Avatar
Has anyone here used EBC pads on their front brakes?
Old 03-24-12, 03:56 PM
PureDrifter
BahHumBug
i think you're talking about the brake disc pad spacers, there's 2 little steel clips per caliper (one per pad) that spaces the pad out from the bottom of the inside of the caliper.
lay the old pad over the new EBC pad, if there's a little extra material in the pad plate itself to compensate for the lack of spacer, you can run it without the spacer. if there isnt, you should still be able to slide the spacer on even without the indent.
Old 03-24-12, 05:20 PM
maximus54
maximus54's Avatar
I don't have the old pads, so i have nothing to go off of. Maybe I can find pics of stock pads with the spacers installed. Right now I'm just dealing with the horrible squeal coming from the pads that hopefully isn't due to the spacer missing, and is just the break-in coating.
fujxyooj
04-18-13 04:01 PM
jpw
Suspension and Brakes
01-27-13 08:13 AM
JBasco20
02-26-10 07:28 AM
denvergs4
10-22-07 07:23 PM
933005spd
SC- 1st Gen (1992-2000)
06-04-01 06:55 AM
Quick Reply: EBC Red Pads install question
