99 ls-400 instrument cluster removel
Old 03-21-12, 06:15 PM
tb2509
tb2509's Avatar
Question 99 ls-400 instrument cluster removel
I found the two slots at 10 an 2.Will the cluster just come out or am I missing something. the speedometer quit working when it got warm worked all last winter problem started last summer.Worked sometimes I guess I need to send it off for repairs
Old 03-22-12, 01:11 AM
Luxor
Luxor's Avatar
Take off the lower plastic bezel, there should be two more screws at the 8 and 4 position.
Old 03-22-12, 06:26 PM
tb2509
tb2509's Avatar
Thanks, wife took the car on a trip when she gets back I'll look at it again.She said it took about 100 miles then it started working.Tomorrow it will quit again
Old 06-22-12, 05:28 AM
phlorida
phlorida's Avatar
Do you have any guidance on removing the lower plastic bezel? This is the bezel with the gauge dimmer and the trip reset buttons, correct?
Old 06-22-12, 07:04 AM
billydpowe
billydpowe's Avatar
dont know how true this is, but have read in summer grease gets sticky and this is what holds the needle down.
I have not read where it is or "how" to remove it. but on mine, a slight tap on the top of the dash, and it is working as usual.... post your results. I have had trouble finding the top "slots" , no trouble with the screws. a couple of photos sure would help..
Old 06-22-12, 09:16 AM
phlorida
phlorida's Avatar
Interesting. I can feel the slots at the top of the cluster easily using a straight screwdriver. I have not tried to release the clips until I can figure out how to get to the lower screws. The screws are hidden by the lower bezel and it isn't obvious to me how to remove that bezel. From the looks of the tabs on my replacement cluster and the position of the switches in the bezel it seems like it should pull straight backwards. I have tried that and it hasn't budged - I don't want to pull much harder until i confirm that is the procedure.
I believe that you are correct about the grease causing the gauge needles to stick. My experience is the same - if I smack the dash they start working.
Old 06-22-12, 10:37 AM
steve2006
steve2006's Avatar
The lower section is just held with clips, grap it and pull is the only advise I can offer, it can be very tight but shouldn't break.
Old 06-22-12, 10:51 AM
phlorida
phlorida's Avatar
That is exactly the advice that I was looking for. Thanks!
Old 06-22-12, 10:54 AM
steve2006
steve2006's Avatar
The picture is for a RHD 1997 model but you can see the 2 clips located between the 2 plug sockets.
Old 06-22-12, 03:31 PM
phlorida
phlorida's Avatar
That worked, thanks all! The gauge cluster is swapped. The steps that I took for the swap are detailed here: https://www.clublexus.com/forums/ls4...998-ls400.html
Old 06-23-12, 07:24 AM
Luxor
Luxor's Avatar
I am glad it worked out!
phlorida
09-26-17 01:50 PM
wbzautocus
03-09-16 12:58 PM
kopo6329
08-25-15 10:40 AM
Rad1
10-15-12 04:39 PM
Quick Reply: 99 ls-400 instrument cluster removel
