Headlight difference 1992 to 1993
Old 01-25-12, 06:10 PM
trcarnut
trcarnut's Avatar
Default Headlight difference 1992 to 1993
Can I put a 1992 headlight, fog light, turn signal assembly and grill into a 1993 car? They look the same but the dealer says they maybe different?
Old 01-25-12, 09:16 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
will bolt in fine but you will need to change the harness as '93/94 cars use H4 plugs for the lows.
Old 01-25-12, 10:13 PM
trukn1
NELOC Mod
trukn1's Avatar
Everything will bolt up physically, as Pure drifter mentioned, Difference is in the headlight bulb. You will need to convert the wiring harness from H3 (9004) to H4 (9003) in order to get the headlight bulbs to fit. Fog lights are still the same and the grill will bolt right up with no problem at all.
Old 01-26-12, 12:14 PM
trcarnut
trcarnut's Avatar
Okay that is what I was afraid of the bulbs and wire harness issues. Thanks for that update. I like how fast the response is and the amount of traffic there is on this web site. Very impressive.
Old 01-26-12, 12:57 PM
steve2006
steve2006's Avatar
The JDM one piece units look nicer on the 90-94 model but they are for RHD set up only unfortunately
Chinky2
RC - 1st Gen (2015-present)
07-01-15 07:51 AM
LexiLex
01-25-13 12:20 PM
Sash
02-02-09 09:22 PM
Czechlex
Lighting
12-11-07 09:05 AM
DroppedLex
Lighting
12-27-02 02:36 AM
Quick Reply: Headlight difference 1992 to 1993
