Sway Bar End Link Removal 90 LS400
Old 10-05-11, 09:48 AM
jdog0411
jdog0411's Avatar
Default Sway Bar End Link Removal 90 LS400
As other have run into before, I'm having issues removing the sway bar end links so I can replace them with new ones.
I can get the nut spinning just fine (it's not frozen), but the entire bolt is spinning too, so I can't remove the nut. I've searched and found that some have used pliers to hold the bolt and other's mention a hex key or something to hold the bolt in place while the nut is removed. Were is the hex used? I have tried putting vice grips on the bolt by the rubber bushing section but it is slipping off.
Any tips would be appreciated.
Old 10-05-11, 10:09 AM
awdandrwd
awdandrwd's Avatar
There should be a hex hole in the center of the endlink threaded "bolt" section.
Stan
Old 10-05-11, 10:21 AM
jdog0411
jdog0411's Avatar
Ah, ok.....I was looking on the wrong end I think. I'll go take another look. Thanks!
Old 10-05-11, 11:09 AM
deanshark
deanshark's Avatar
That was a new one for me so I did some searching and it's a 6mm allen wrench. Alot of people are talking about how they stripped the bolt head and had to cut the bolt with nut off. I even looked in my manual and all it says in there is "Remove the left and right stabilizer bar links" no kiddin'. You're replacing the links, right? B/c the bolt isn't supposed to turn and turn.
https://www.clublexus.com/forums/ls4...-link-nut.html
Old 10-05-11, 02:31 PM
jdog0411
jdog0411's Avatar
My intention is to replace them, although my car only has 88,000 miles. I'm getting a clunking noise from the rear so I'm hoping that switching them out may help. The bolt turns...on both sides of the car.
Old 10-05-11, 03:12 PM
LiCelsior
Retired
LiCelsior's Avatar
get a ratchet wrench and a hex bolt socket, and some pb blaster.
MASSMINI
RX - 1st Gen (1999-2003)
06-13-22 08:31 PM
dminah21
09-01-18 08:04 AM
98GSOwner
Suspension and Brakes
03-20-18 01:49 PM
Champstar
06-19-15 07:18 AM
Ripper
09-18-10 07:51 PM
Quick Reply: Sway Bar End Link Removal 90 LS400
