Start "lockout" switch?
Old 09-26-11, 03:37 PM
fishguy55
fishguy55's Avatar
Default Start "lockout" switch?
My 1996 ls 400 with 130k on it has an issue with some sort of lockout switch tied to the shifing mechanism, as in... it won'start sometimes but if i wiggle the shifter in park, or move it out & back into park it will start. The battery is about 4 months old & there's no lack of power. Doesn't sound like a solenoid, it is a flat click but not a lack of "juice" click. When I hit the sweet spot it starts right up. It is getting progressively worse. Ideas? Thanks
Old 09-26-11, 06:03 PM
LEXTEK1
LEXTEK1's Avatar
Depends on where you hear the click. Is it the starter relay clicking or the solenoid clicking? What exactly clicks?
Old 09-26-11, 06:29 PM
RavenTai
RavenTai's Avatar
On most Toyota there is a "neutral safety switch" on the transmission where the shift linkage enters, it will only let the starter engage in park or neutral, it sounds like yours is going bad or out of adjustment.,
Old 09-26-11, 07:02 PM
LEXTEK1
LEXTEK1's Avatar
If the neutral safety switch was bad or out of adjustment would you still hear a click?
Old 09-27-11, 02:44 AM
RavenTai
RavenTai's Avatar
I guess that depends what is clicking,
if the starter is clicking yea bad contacts and plunger in the starter, the shifter movement is placebo.
but There are a couple of relays that will click when you go to start, fuel pump relay goes to high, ac is cut off etc, that could be the clicking he is hearing, in that case neutral safety switch.
Old 09-27-11, 06:18 AM
RavenTai
RavenTai's Avatar
Fish guy, couple things to try, put it in drive and try to start it, is that the same click you hear when starting in park? If you don't get your click, more likely starter issue, Then try starting in neutral, if it more reliable in neutral more likely its the neutral safety switch
Old 10-03-11, 09:57 PM
fishguy55
fishguy55's Avatar
Default Update
Finally contacted my mechanic & he was 90% sure it was the neutral safety switch & 10% starter problem. He removed the switch, cleaned it with brake clean, applied a heavy dose of dielectric grease & reinstalled the switch. As of today the problem seems to have been fixed. Time to keep my fingers crossed. Guess it's about a 6 hour job to replace the starter! Plus the cost of the part.
Old 10-10-11, 01:36 PM
Bott63
Bott63's Avatar
Any update FishGuy?
I'm faced with nearly identical issue! Where exactly is this "Neutral Safety Switch" located?
Old 10-10-11, 02:14 PM
deanshark
deanshark's Avatar
Originally Posted by Bott63
Any update FishGuy?
As it says in post #3 above, "neutral safety switch" on the transmission where the shift linkage enters, In my 93 manual it shows it on the tranny under the exhaust pipe. It also says to take off the front exhaust pipe, I'm not sure if you actually need to, I've never dealt with it.
Old 10-10-11, 02:49 PM
Bott63
Bott63's Avatar
Thanks for the reply Dean! I will look into replacing or repairing this switch tomorrow!
Old 10-17-11, 08:17 AM
fishguy55
fishguy55's Avatar
The mechanic had a heck of a time getting to it... said 2 long extentions on the socket, did not have to drop the exhaust using them. Good lock. You'll soon hear about my new problem!!
Jwebster87
05-10-17 03:08 PM
Eds98LS
16
01-20-16 01:00 PM
Lexus082
SC- 1st Gen (1992-2000)
05-06-11 09:22 PM
python
08-26-08 08:59 AM
modelaford
GX - 1st Gen (2004-2009)
02-22-03 05:52 AM
Quick Reply: Start "lockout" switch?
