Hard pedal after new brake booster! 98 LS400
Old 07-17-11, 12:33 PM
deanshark
deanshark's Avatar
Originally Posted by 99svtvenom
I'm pretty certain that everything is hooked up properly, there are only a couple things that hook up to the booster (master cylinder and the vacuum hose). I have the vacuum line hooked up and the hose does not collapse and it does pull good vacuum from the intake.
I also bought the brake booster from KOI auto parts which is just a local parts shop around the tri-state area (usually pretty good stuff).
Under the manual procedures that were stated above, what is the booster pushrod adjustment? Could that be anything worth looking into?
This is the install procedure for the booster. This is from the 2000 manual; http://home.student.utwente.nl/gombe...rake/br-21.pdf
Old 07-16-16, 12:26 PM
Ls400vog
Ls400vog's Avatar
Default Same problem
I have a 1992 ls400 and I have the same problem I have to push the brake all the way in and even if I press it all the way in it doesn't want to make a complete stop what should I do ???
Old 07-16-16, 02:42 PM
dicer
dicer's Avatar
Check all the friction elements both front and rear, look for leaks, add fluid and bleed the system.
Old 07-16-16, 04:59 PM
AaronUCF11
AaronUCF11's Avatar
Cant say ive heard of air in the system causing firm brake pedal. If its hard and as you say and in effective at stoping, it has to be a booster issue.
Old 07-16-16, 08:29 PM
dicer
dicer's Avatar
I was responding to Ls400vog's question he said pedal goes all the way and won't make a complete stop.
Said nothing about a firm pedal.
ruger
03-29-23 10:40 AM
Azhar22
Suspension and Brakes
01-12-14 07:55 AM
Lexus082
10-13-12 05:40 PM
gcam77
02-06-08 08:53 PM
Lexs400
Maintenance
10-09-03 10:19 AM
Quick Reply: Hard pedal after new brake booster! 98 LS400
