ls circuit breaker or fuse problem hellp
Ok so out of no where my power locks and power seats gas opener aren't working.I've read its a 30a fuse but where. Or a circuit breaker but where. What do I do I also have an after market alarm. I've tried resetting the thingy. Taking out battery for a few mins looked under the kick pannel don't see what I have to replace help thanks guys
Behind the kick panel on drivers side, I can't remember if it's the lower panel or center panel but, there's the junction box #1 A and B. You need to take the junction box down, iirc it's a 13mm bolt which pulls out the wire harness. Then you can get to the one above it. What you're looking for is up in the top one. Idk which one it is but it might show on the cover for the lower box.
All this technology, and they can't put all the fuses in one spot???
Hello
Attached are the location of fuses for the 2000 LS400. It should be same for earlier models also and the boxes have a description of each fuse and the fuses are the ordinary two prong ones, except for the relays which are normal Toyota 4 or 5 pin relays but I doubt any relay is busted, it could be a simple fuse.
So hope this helps.
So hope this helps.
jackleu
08-05-06 07:28 PM
