Water Pump R&R - 97 LS400
Old 03-16-11, 03:55 PM
smamas
smamas's Avatar
Default Water Pump R&R - 97 LS400
So I did my timing belt and everything, including the WP about 5K ago. Looks like I now have a small leak!
When I did the install I used Red Silicone, and it looks to be leaking. What do you guys recommend as the sealant? I don't think I want to do the red silicone again! I know I had the surfaces very clean and the WP was new. Torqued the bolts to spec. DANG!
Old 03-16-11, 05:40 PM
CitySlaka
CitySlaka's Avatar
Oh no I just did mine with red.
Old 03-16-11, 06:37 PM
deanshark
deanshark's Avatar
Different colors just means the temp range. Red is up to 650*, copper is 700*, and blue is 500* which is what I have on mine and I haven't had any problems with it, I changed my WP last year. (14K miles ago) If you have a leak it's not b/c of the red sealer, you might have missed a spot or it could have dried too much before you installed the WP and it's not sealing.
Funny thing, I even used the blue sealant when I changed my 4" speakers to 5 1/4". (Directions from lexls.com) I just didn't feel like going to the store to get something different. Just use what ya got.
Old 03-18-11, 08:17 PM
billydpowe
billydpowe's Avatar
this may or may not help anyone, but I will pass it along. we have put on 4 water pump/ TB combos the last few weeks, and on one of them, the pump came with alignment pins in the new pump, we didnt see that and the pump didnt quite seat properly, so we took it off and saw the pins. removed them and then it was fine. I am quite sure it would have leaked at some point. we use red sealer, but it would not matter, red, blue, copper, all are ok.
Old 03-23-11, 03:06 PM
sethjon
sethjon's Avatar
Permatex. Its black and gooey but its the best. Use the type that is somewhat soft.
Old 03-23-11, 06:45 PM
randal
randal's Avatar
Before you chalk the leak up to the WP, recheck the hoses. Mine leaked a bit after replacing the TB/WP but it turned out to be the upper hose leaking. The clamps are not the best and I fixed it by using a screw worm-gear type clamp.
GS714
03-03-12 12:41 AM
Dj Rando
07-26-06 02:04 AM
97-SC300
Performance & Maintenance
07-16-06 10:10 PM
Lilflip#2
03-19-06 10:38 PM
retrodrive
03-12-02 11:58 AM
Quick Reply: Water Pump R&R - 97 LS400
