98 Ls400 Power Steering Control Valve
Old 03-12-19, 02:33 PM
Juelz21
Juelz21's Avatar
Default 98 Ls400 Power Steering Control Valve
I have a 98 Ls400 and for a while its been leaking power steering fluid. I can smell it getting burned off sometimes aswell. My alternator hasnt had any issues so i dont think its dripping on to it. My question is does the 98 model of a Power Steering control valve? I know by reading the forums that thats usually the bad part but i am yet to read about it on the 98+ models, so i want to confirm its actually there before i buy it. Thanks for the help.
Old 03-12-19, 03:59 PM
bradland
bradland's Avatar
IIRC the Air Control Valve appeared circa 1994 so yes 98's def have it.
Scraape (03-12-19)
Old 03-12-19, 06:57 PM
Scraape
Scraape's Avatar
yes, they have one. make sure it's tight or it'll **** ATF everywhere
you can delete it, or opt for the metal version (the plastic ones aren't as durable, ask me how i know.)
17630-16040 https://www.ebay.com/itm/Toyota-Lexu...M/152971694827
Old 03-12-19, 09:02 PM
Sin1UZFE
Sin1UZFE's Avatar
What would you use to delete it
Old 03-12-19, 09:58 PM
JonnyO78
JonnyO78's Avatar
To delete you use a basic M14-1.50 oil plug. I used this one from NAPA.
Old 03-12-19, 10:02 PM
Sin1UZFE
Sin1UZFE's Avatar
Thanks, what did you do with the vacuum lines?
Old 03-12-19, 10:39 PM
JonnyO78
JonnyO78's Avatar
Plug them on the plenum and intake. I have seen a few people route a hose from the plenum to the intake to increase the RPM slightly, but it's unnecessary, and there are better ways to adjust idle RPM if that's one's goal.
Old 03-12-19, 11:32 PM
Sin1UZFE
Sin1UZFE's Avatar
I don't know what plenum is....
Old 03-13-19, 10:05 AM
JonnyO78
JonnyO78's Avatar
The air box over the RH valve cover after the air sensor. This is from my 1994. The plenum, or air box, is circled. The yellow blob on the left (RH) is a screw I plugged the broken stem with. The yellow on the right is a short bit of the vacuum hose with a bolt stuck in it. And you've deleted your power steering air control valve.
Old 03-13-19, 10:51 AM
Sin1UZFE
Sin1UZFE's Avatar
Sweet thanks, it looks very different from my 99 tho
Old 03-13-19, 01:38 PM
bradland
bradland's Avatar
Your 99 will look like this...
Follow the vacuum lines and plug where they terminate.
Tappy (03-11-23)
Old 03-13-19, 01:41 PM
Sin1UZFE
Sin1UZFE's Avatar
Gotcha so basically this....
Old 03-30-23, 05:46 PM
Tappy
Tappy's Avatar
This a link that will show you the diagram above. LINK VACUUM PIPING
scrapinls
19
02-06-24 02:25 PM
theschoens
48
10-28-18 05:29 PM
Sportznuts
03-17-07 07:31 AM
Quick Reply: 98 Ls400 Power Steering Control Valve
