HELP 91 ls400 only have 1st and 3rd gears
Old 08-12-10, 01:51 PM
josh4495
josh4495's Avatar
Exclamation HELP 91 ls400 only have 1st and 3rd gears
hi i am a owner of a 91 ls400 and my transmisson is not shifting properly, for instance when i leave a stop light i have to put it in second cause if i dont it will go 1st to O/D lock up i supose, but when i put it in second it just acts like it goes from 1st to 3rd so i have a lil more power, The O/D light flashed on the dash!!!
but ever once inawhile if i drive the car for a few it will shift just fine! and the O/D light will not flash
i alson have a trac light on also? possible just the wheel sensors i suppose?
Old 08-12-10, 03:37 PM
RA40
Super Moderator
RA40's Avatar
How does the tranny fluid look, red or black?
We'll go from there...
Old 08-12-10, 04:10 PM
curepunx
curepunx's Avatar
Depending on the color of the transmission fluid, my next guess would be: solenoid valves #1 & #2 located in the transmission oil pan. You can find them online for about $150 shipped. I had the same issues, with the gear shifting and the O/D light flashing but if i were you, id check the fluid first, followed by the check-engine-light codes (the number of blinks on the OD light). Use www.lexls.com
There's also this thread https://www.clublexus.com/forums/ls4...e-63-68-a.html
Goodluck!
Old 08-18-10, 10:38 PM
josh4495
josh4495's Avatar
okay its kinda black with a red tint! every now and again the tranny shifts perfect and i ran the codes it gives me code 63,67 and also on the traction control it gives me code 51 any fix for that
Old 08-18-10, 11:50 PM
RA40
Super Moderator
RA40's Avatar
This older thread for the 63 and 67:
And this one for the 51:
https://www.clublexus.com/forums/mai...s-51-22-a.html
Old 08-22-10, 05:14 PM
josh4495
josh4495's Avatar
ok new problem going down the interstate ang if it goes over 2500rpms all tghe dashlights come on and the engine starts to heat up????????
Old 08-22-10, 09:01 PM
RA40
Super Moderator
RA40's Avatar
Check airflow to the radiator. Take the air snorkel off and look between the condenser and radiator. If there are debris clear it out. Flush coolant if it has not been done and new thermostat.
lexalex250
11-26-23 12:18 PM
s14a
27
05-24-18 09:19 PM
hotdawwg
14
03-16-16 03:28 AM
ef9racer
04-21-11 10:35 AM
MIN007
02-10-06 11:48 AM
Quick Reply: HELP 91 ls400 only have 1st and 3rd gears
