AC light blinking
Old 06-09-10, 06:19 PM
cgreenberg
cgreenberg's Avatar
Default AC light blinking
Folks, anybody know why the A/C light (the little green light in the A/C button) would blink?
Old 06-14-10, 07:08 PM
mrwinkle
mrwinkle's Avatar
It means your ac compressor is not operating, is the are blowing cold?
Old 06-15-10, 05:04 AM
cgreenberg
cgreenberg's Avatar
mrwinkle, thx so much for the response. No, at the time it was not blowing cold air. Yet after turning it on and off a few times it did so I don;t think it's the compressor in my 98/77k miles?
th you
Chip
Old 06-15-10, 06:18 PM
Lexozz
Lexozz's Avatar
If there is not enough freon the compressor will not spin and the A/C light will blink. Have it checked out.
Old 08-31-11, 04:07 AM
rishi
rishi's Avatar
was it freon or the compressor? mine started blinking yesterday, going to get it checked out tomorrow...
Old 04-06-24, 08:16 AM
annonymous99
9th Gear
annonymous99's Avatar
My AC is blowing cold and I have replaced the relay and the belt but randomly the AC will stop blowing cold and the light will start blinking pushing the button causes it to blow cold again there are no error codes on the AC diagnostic. What is the cause?
Old 04-13-24, 09:36 PM
afanboy
afanboy's Avatar
Blinking light means low refrigerant pressure, and compressor not running to prevent damage. Sometimes the refrigerant pressure sensor that's in the compressor goes bad and reads low/no refrigerant, even when refrigerant pressure is good. If you are 100% sure the refrigerant pressure is good and it's the pressure sensor that's bad, you can override that sensor failsafe as a temporary measure until you replace the compressor. As far as I know, there's no well known source or method to replace only the pressure sensor on the compressor. The entire compressor has to be replaced. Of course you can then pawn off the basically good compressor to someone who drives a beater or use it for parts.
Old 04-23-24, 07:11 AM
BNastee
BNastee's Avatar
I've been looking in to a flashing A/C light on a 1996 quite a bit lately. *I think* that the light blinks anytime the compressor spin speed is not what the ECU expects. *I think* the two wires that go in to the back of the compressor measure the speed for this. In two cases recently two different compressors had torn rubber bushings in the compressor clutch that would intermittently be able to spin the compressor and cause the A/C to work intermittently.
I wonder how many compressors have been evacuated, replaced and recharged because of simply torn rubber in the compressor clutch. You can change the clutch with 10mm ratchet without even jacking the car up.
VCLHaynes
08-10-16 12:44 PM
VCoop
07-18-16 11:24 AM
Dirty SC
Performance & Maintenance
02-26-10 10:00 AM
Jwitty
Maintenance
10-14-03 08:40 PM
Quick Reply: AC light blinking
