just bought new antenna mast
Old 06-24-02, 12:43 AM
rhayward
rhayward's Avatar
Lightbulb just bought new antenna mast
I read some posts. So I went to the dealer here in Fremont to buy my new mast $80.00. Any hints I should know before doing the job. Motor works just no movement. I have a 94 Ls400
Thanks
Old 06-24-02, 08:32 AM
wwest
wwest's Avatar
Default Easy
Really easy DIY job.
Remove the outside nut/washer assembly, pull the old antenna out firmly but S L O W L Y, note the orientation of the gear track on the nylon tail, insert the new nylon "tail" until you reach a hard "stop", have someone retract the antenna (turn the radio off).
Old 06-24-02, 08:44 AM
rhayward
rhayward's Avatar
Default what is agood tool
what should i use and not scratch the paint
thanks i gonna do it today
Old 06-24-02, 03:32 PM
VVT-i
VVT-i's Avatar
A needle nose piers that will fit into the slots.
Hint: after removing the nut on the antenna. Go in the car, hold the AM buttom and the CD buttom at the same time. If you don't have the factory CD, then use the last buttom. Then turn the key on with your other hand (while you right hand is holding AM and CD buttoms). You will see the radio show " Ant" on the display.
Make sure there's no cable left in the motor. Sometimes the plastic cable broke and stay inside the motor. Compare the new antenna with the old one(at the end of the plastic tip).
Old 06-24-02, 11:04 PM
rhayward
rhayward's Avatar
Default successsssssss
it worked and it sounds great. Thank you everyone for your help.
I will help out on info as I learn more about my Lexus
Old 05-01-03, 03:41 PM
Arun
Arun's Avatar
Can this work in a Mark 1 GS300? or is there another way ?
pjh706
RX - 1st Gen (1999-2003)
09-24-17 01:13 AM
friarush
04-23-15 10:28 AM
jmjatlanta
04-25-11 05:53 AM
SC400james
11-10-04 06:21 AM
Lexson
SC- 1st Gen (1992-2000)
12
09-18-02 06:35 PM
Quick Reply: just bought new antenna mast
