No power steering at idle
Old 05-31-10, 05:58 AM
hqle
hqle's Avatar
Default No power steering at idle
I have a 95 LS400 with 175K miles bought recently. From the beginning the steering seems very light and did not tighten up at higher speeds. Drove it 2K miles after purchase and it seems OK. Brought it to a local shop this weekend to replace the air control valve (at bottom of power steering pump) since it was leaking, also had him clean the solenoid in the rack. After working for a few miles, the power steering now provides very little power assist at idle. At higher speeds, the power steering gets much better. If you look at the fluid in the power steering resevoir, the fluid is not flowing at idle (as it did before). If you increase the engine RPM, then the fluid starts flowing again. The local shop recommends to replace the power steering pump. He quoted $625 for the job (a remanufactured pump and labor). The local shop seems honest and competent but they don't handle much toyota/lexus work, they are honda/acura specialists. Have a few questions before plunking down significant $$$:
1) Seems too much of a coincidence that the power steering pump died after work was done on the power steering system. Could they have made some mistakes during the air control valve replacement work ?
2) Does the power steering pump replacement recommendation sounds right ?
3) Any recommendation for mechanics in the Orlando FL area that has more toyota/lexus experience and that you trust ?
4) Should I go with a rebuild pump or an OEM pump (cost difference is about $270). I'm leaning towards the OEM since the original lasted 175K miles.
Thanks.
Old 05-31-10, 09:47 AM
Thermactor
Thermactor's Avatar
did the mechanic bother to reconnect the solenoid's electrical connector to the rack? Peek under there to see for yourself. He might have forgotten to plug it back in.
Old 05-31-10, 09:58 AM
hqle
hqle's Avatar
Checked the electrical connector to the solenoid and it is connected. There are also chisel marks on the nut so he did remove the solenoid to clean it.
Old 05-31-10, 11:01 AM
JimsGX
JimsGX's Avatar
Did the mechanic put the recommended Dexron/Mercon III ATF in the system, or did he use regular power steering fluid?
Old 05-31-10, 04:30 PM
hqle
hqle's Avatar
Just to be on the safe side, I brought the mechanic Mobil synthetic ATF to use and he refill the power steering with this stuff.
Neofate
33
08-30-20 07:36 PM
dashan
11-12-14 08:04 PM
Dx3
Suspension and Brakes
32
04-07-13 07:36 AM
Shaar
Performance & Maintenance
07-15-08 10:58 AM
SC300_704
12-12-07 08:59 PM
Quick Reply: No power steering at idle
