Squealing from A/C
Old 05-08-10, 05:42 PM
amcdonal86
amcdonal86's Avatar
Default Squealing from A/C
1997 LS400
Hi,
I'm having a strange problem that comes and goes. My A/C seems to squeal when I have the fan blowing. The noise never occurs when the fan is off, and it seems to only occur occasionally when the fan is blowing at low/medium speed, although sometimes it can happen at high speed.
It does it even if I turn off the "AC" button, so I don't think it's a belt in the engine bay. It appears to be coming from the blower motor.
Description:
*high pitched
*moderate intensity
*only happens with blower motor on
*sometimes seems to go away when making a left/right turn
*sometimes cycling through different modes and turning fan on and off and then on again will make the noise go away
I have a feeling something is trapped in the blower motor. Do you guys know how I can remove it to check?
Old 05-10-10, 11:42 PM
amcdonal86
amcdonal86's Avatar
Sorry to bump this thread. Does anyone have any idea how to get into the blower motor? Does the whole dash have to be disassembled? This is a '97 model.
Old 05-11-10, 06:18 AM
python
python's Avatar
find someone with mitchell on demand and ask for an exploded view
Old 05-12-10, 12:46 AM
Sixdown
Sixdown's Avatar
Alldata says you only need to remove the glove compartment to remove the blower. It's located next to the cabin air filter.
Old 05-12-10, 06:46 AM
amcdonal86
amcdonal86's Avatar
How do you remove the glove compartment?
Old 05-18-10, 03:59 PM
amcdonal86
amcdonal86's Avatar
Anyone?
Old 05-18-10, 04:10 PM
PK_Celsior
PK_Celsior's Avatar
if you can wait till thursday i will post up some pictures and a walkthrough on how to do it!!!!! i have done it plenty of times!!!!!!
Old 05-18-10, 04:30 PM
amcdonal86
amcdonal86's Avatar
OK! That would be great!!! Thank you so much!
Old 05-19-10, 01:38 PM
amcdonal86
amcdonal86's Avatar
Hey, I think I found instructions. See post 3 from the link below:
http://us.lexusownersclub.com/forums...howtopic=48897
Old 05-19-10, 03:58 PM
etex
etex's Avatar
Have you considered that the noise may be from the drive belt slipping when the compressor clutch engages? With A/C on and engine idling, raise the hood and watch the compressor clutch in relation to the noise.
Old 05-19-10, 05:54 PM
amcdonal86
amcdonal86's Avatar
The noise was there regardless of whether the A/C button was on or off. It was directly related to the fan being on or off.
I am speaking in past tense, because I replaced the blower motor with a $67 "Four Seasons" aftermarket blower motor today. It worked great! The biggest pain was transferring the old fan blade "wheel" from the old motor onto the new one. That thing was seized on there! I had to heat it up with a candle to get it off!
Fhobbs
08-31-18 06:36 AM
CMM
09-14-14 06:01 AM
Jay87T
04-08-11 12:27 PM
indo79
09-11-08 07:52 PM
xfirechief
05-21-06 10:37 AM
Quick Reply: Squealing from A/C
