1993 LS 400 cluster illuminating needles
Old 06-14-02, 04:40 PM
fantum10
fantum10's Avatar
Default 1993 LS 400 cluster illuminating needles
I own a 1993 LS 400 and I have no problems with it except tachometer needle does not eliminate. The question I have to ask to the forum , is if I take an old cluster and remove either tachometer or speedometer needle from an old 1993 cluster to use in my current cluster in the place of the tachometer ,will it work. I thank all of the members for a reply.
Old 06-14-02, 07:31 PM
VVT-i
VVT-i's Avatar
If the cluster come from the same year I think it should be o.k. But make sure it's work before you buy it and becareful when you take it apart. Be gentle.
Old 09-30-03, 10:11 AM
kamtra
kamtra's Avatar
Even though this is a year old i'm going to answer it because i just did it. The Needle clusters can be switched from RPM to SPeedo but you have to also switch the circuit boards attached to the needle clusters. The needles themselves are the same but the tiny circuit boards are different. be sure to pull the entire needle cluster out and not just the needle itself. Immediately after removal, tape the needles in place to keep them from rotating on their own. Even rotating half way around can knock the calibration out of whack.
Old 09-30-03, 07:22 PM
350z
350z's Avatar
Default another good thread about this topic...
https://www.clublexus.com/forums/sho...threadid=40025
gtstcactus
12-26-13 05:32 AM
md531e
12-12-10 01:42 PM
djkevin510
SC- 1st Gen (1992-2000)
01-15-10 11:22 AM
g3t0ut
10-21-09 01:24 PM
HotBoy
12
01-03-04 10:32 PM
Quick Reply: 1993 LS 400 cluster illuminating needles
