Funny warning light
Old 02-21-10, 07:36 AM
renatodato
renatodato's Avatar
Default Funny warning light
After doing a brake job on my 91 LS 400, a circular warning light came on in the lower right hand corner of the cluster. It's circular with broken lines on either side of the circle. Can someone identify this and how do I reset it?
I appreciate your help; I don't know if it's a safety issue. The car brakes fine.
Rey
Old 02-21-10, 10:43 AM
trukn1
NELOC Mod
trukn1's Avatar
ABS sensor. You may have clipped or broken a wire.
Old 02-22-10, 12:14 PM
Lsportline43
Lsportline43's Avatar
How serious is this issue? I've seen it before on a LS400. Easy to figure out which sensor is the issue? Or if not the sensor what particular ABS component is acting up?
Old 02-22-10, 01:43 PM
Wufen
Wufen's Avatar
i'm new here, but i've had the same light on my 97 for a while now, but mine happened when my rear passenger tire popped, i want to know the answer too!
the manual says its some "brake pad wear limit warning light"... (scratches head)...
Old 02-22-10, 02:42 PM
amcdonal86
amcdonal86's Avatar
Yes, it is the brake pad wear limit warning light. If yours has come on, it's either defective, or your pads have reached the point where Lexus wants you to have them replaced. It will require replacing the sensor as well. Unless you can figure a clever way out to trick the sensor.
It is NOT the ABS sensor.
Old 02-22-10, 02:47 PM
evopanop
evopanop's Avatar
I just recently had all of my brake pads (front and rear) replaced and that particular light is on. Does this mean that the sensor is bad? Is there any way to reset it, to know for sure?
Old 02-22-10, 02:58 PM
amcdonal86
amcdonal86's Avatar
It may have been unplugged or removed.
Old 02-22-10, 08:27 PM
Lsportline43
I wonder why trukn1 said it's the ABS light. Anyways I'm guessing the ABS light is labeled "ABS"?
Old 02-22-10, 10:17 PM
amcdonal86
amcdonal86's Avatar
Yeah, I think if your ABS was malfunctioning, you would have the ABS light illuminated. But for sure, that circle with the broken lines is the brake wear sensor indicator. When I changed my pads, I unplugged it to see what it would do and the light came on. When I plugged it back in, it went off. The sensor is located on one of the right front brake pads.
Old 02-23-10, 12:42 PM
trukn1
NELOC Mod
trukn1's Avatar
600 miles of driving and looking thru threads while tired will do that to you. I was looking at diagrams and looking at the pad wear sensor, meaning to type that as well, but came out as ABS. Reminds me that I need to be more careful when checking threads dead tired. LOL!! apologies. Pad wear sensor is the correct answer. It may have gotten pinched or broken when you changed the brakes. In some cases you can disonnect the battery to try to reset it, but in most cases you would have to replace the sensor. It is not an expensive fix.
Old 02-23-10, 03:14 PM
Lsportline43
Thanks for the clarification. The wear indicator is on the front passenger side caliper?
I'm interested in getting my pad wear sensor replaced or fixed, so that it doesn't illuminate on the dash anymore.
P.S. Where does everyone get oem Lexus parts from? www.oemlexusparts.com? Or any other suggestions?
Old 02-24-10, 10:35 AM
Wufen
Wufen's Avatar
yea i'd prefer to find some way to just reset it, i could care less about it since i keep up with my brake pads myself, i'm just like lsportline, the light really bothers me hahaha
stevehoch
09-29-15 11:29 AM
Caniac14
09-30-14 01:48 PM
pfcrayb
03-14-14 12:11 AM
topgun129
10-14-09 01:41 PM
nem364
11-26-08 11:53 PM
Quick Reply: Funny warning light
