a/c control assembly
Is there a way to check a/c control assembly without pulling the whole dash including steeing wheel? I am working on heat and about to check several circuits that could be bad I guess, a/c assembly being one of them...me te tree
Colin
3UZ-FEEEE
To perform the diag test:
here are the codes and what they mean:
Note: Code 21 - Open or Short in Solar Sensor Circuit.
In other words a code of 21 is normal if the sensor is not receiving enough light(from the Sun).
I hope this helps.
"Running the A/C system diagnostics: When switching ignition ON push RECIRCULATION and AUTO buttons together and watch the LCD aircond. system screen normally used for temperature settings for a numerical code indicating the problem area. BTW, zero zero (00) means normal. First, all indicator lights will flash 4 times, then a buzzer beeps. When error codes are displayed a short while later, slower display (step mode by repeatedly pushing Fresh) can be activated by pushing FRESH. Hitting OFF stops the diagnostics."
I hope this helps.
what else to do
Everything helps guys, but diagnostic test through a/c unit shows nothing. The problem is I have no heat still and eberything I check is working properly. I just don't get it. If all diagnostics are good tstat is good water controls good hell everything I can possibly think of or read about is good, then what to do next?
Colin
3UZ-FEEEE
How about the blender door? the ones that blends cool ac with that of the engine. Do you hear the door opening/closing when you increase the temperature?
I remember this was a big issue in my previous car (Mark VIII) and the blender door arm would break, causing the A/C to be stuck in either absolute HOT, or absolute COLD mode.
nickCT
12-28-07 12:21 PM
RichardM
06-23-02 08:41 PM
