Traction Control Light
Old 01-13-10, 10:38 AM
Wags
Wags's Avatar
Default Traction Control Light
1994 LS400. Trac Light comes on periodically after driving, thus no trac control. Goes off after restarting car and occasionally returns (not every day). Been diagnosed as trac control module that is overheating, $1500 fix. Anyone else experience this? can the module be fixed, or used one relaible replacement. Also I have bought Bosch triple paltinum plugs for replacement, any good? Still haven't installed them.
Brian
Old 01-13-10, 11:47 AM
93ls40082
93ls40082's Avatar
I have the same problem. the light comes on occasionally and goes off on its own. the traction control does work in the car. If you fix the issue please ley me know what you did.. thanks..
Old 01-14-10, 11:04 AM
bacaudio
bacaudio's Avatar
I had this issue and it morphed into it always being on now and the traction control does not work at all now. I guess I just don't worry about it because I like having full control of the vehicle. But I would love to know why it does this. Also the best spark plugs you can get are iridium. Far superior to platinum. You can find some here:
http://www.*********************.com...ark-plugs-p-10
Old 01-16-10, 01:55 AM
1994LS400
1994LS400's Avatar
Default Traction Control Light code 43
94 LS400 Same problem. The TRAC code is 43, I cleared the code, go for road test, the code reappear, the code 43 is not listed in the TRAC OBDI Diagnostic Codes List, What is the code meaning?
How do you know the traction control does work or not in the car? thanks.
Old 01-16-10, 04:53 AM
Asia-H.T.
Asia-H.T.'s Avatar
Haven't got any serious electronicaly issues with my car, I'm very happy with that.
I'm running Nology Silver spark plugs. They don't last as long as Iridium's or Platinum's. But they have a better spark
Old 01-16-10, 12:03 PM
curepunx
curepunx's Avatar
Brian
Well, firstly make sure to run the diagnostic correctly to get a proper code reading. If it's anything like a code 43, and it might require a new module, then you might want to try a junkyard to save some money... www.car-part.com
or even get a 2nd opinion at another shop...
Goodluck!
Old 01-16-10, 10:37 PM
AzHotLS
AzHotLS's Avatar
A long shot, but it could be the nitrogen canister:
http://us.lexusownersclub.com/forums...howtopic=55610
To check and clear the codes yourself:
http://www.lexls.com/tutorials/intro/codereading.html
Old 01-17-10, 01:27 AM
1994LS400
1994LS400's Avatar
Default Thanks, Traction Control Light code 43
Please help me make sure the code reading is correct. I got the code 43 on TRAC light (Four times first -- pause 1.5 seconds --- three times second)
Old 01-17-10, 06:28 PM
AzHotLS
AzHotLS's Avatar
You probably need TRAC in Colorado, but here in AZ, I don't need it and when it came on all the time on my 90, I just ignored it.
Here's a couple threads mentioning code 43:
https://www.clublexus.com/forums/ls4...shing-agh.html
http://us.lexusownersclub.com/forums...showtopic=1091
I wish I could help more.
Old 01-17-10, 11:03 PM
1994LS400
1994LS400's Avatar
http://us.lexusownersclub.com/forums...howtopic=46619
Thanks!
Old 01-18-10, 10:01 AM
AzHotLS
AzHotLS's Avatar
Are you saying that something in that thread helped you fix your problem? If so, what?
Old 01-18-10, 11:40 AM
1994LS400
1994LS400's Avatar
Didn't fixed, but that thread helpful.
Old 01-19-10, 01:09 AM
1994LS400
1994LS400's Avatar
The TRAC light on after driving two or more blocks. I will check the brake fluid, and post here then. Thanks.
Old 02-04-10, 06:06 PM
nopcbs
nopcbs's Avatar
Default Odd but true
I have a 92 LS400 that we have had since 1993. Best car I have ever owned...including BMW and MB.
Our LS had same symptom you describe...periodic lighting of traction control warning, but no failure of actual traction control function.
Well, last summer I noted that my brake fluid level was going down every few days, even after I would top it off. Had recently had pads replaced and thought cause of leak was loose bleed valve. Wrong. Real cause was that brake line running to rear wheels had corroded hrough and was losing brake fluid. We live in salt-using Michigan. Had line replaced with coated line ($500).
Now here is the kicker. Ever since the brake line was replaced, the traction control light has not lit except when the traction control is actually working. No more false warnings. I think the light was going off because of a very slight leak in the brake lines. Just a guess, but there it is.
- nopcbs
Brian
Gtzfabb
04-25-16 11:52 AM
F350
10-19-13 11:52 AM
Lapraka
07-14-12 12:53 PM
drsaab1
02-11-06 04:55 PM
dunn378
01-22-06 11:10 AM
Quick Reply: Traction Control Light
