ps fluid question (type)
Old 01-08-10, 11:23 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
the "OEM Toyota" power steering fluid is just regular old DEXRONIII/Mercon spec trans fluid, same as you find in many domestic cars...
Old 01-08-10, 11:28 AM
3UZFTE
3UZFTE's Avatar
OP... If you go to your local gas station, they will have a generic Dex/Merc fluid that you can put in there and it cost like $2. I am not trying to tell you what to run in your car, I am just telling you the best way to save a few bucks because it's not like your PS system sees the same friction and other stress that oils see. And If your not an expert, please don't say i'm pretty sure it's better, cause they are different. I have seen engines come in with Amsoil after 10-15k miles and they need a new motor, which they claim you can go 25k... I have never seen someone have any issues at any of the dealers or repair places I have worked at unless it was long over the oil change date/mileage, but never under 3k miles.
Old 01-08-10, 11:53 AM
7schulz
7schulz's Avatar
Amsoil only claims these things, they have never ponyed up and proved it by getting the proper specs. Would I use it, sure, would I go 25K no way in hell. DYODD
Old 01-19-10, 06:22 PM
kennylexsc
kennylexsc's Avatar
I go with the lexus manual transmission fluid dexron II or III only, no other stuff, that's why the manual says this is it,
Old 01-29-10, 05:57 PM
Bill Dowd
Bill Dowd's Avatar
Originally Posted by 7schulz
Pure please clarify
http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
The synthetic base oil enables excellent performance even in the severest of operating conditions. It offers outstanding gear shifting and power transfer performance versus conventional ATF fluids. The inherently high viscosity index and stability of Mobil 1 Synthetic ATF help protect against thermal breakdown at high operating temperatures, while still providing outstanding performance at very low ambient temperatures.
Mobil 1 Synthetic ATF combines high-performance synthetic hydrocarbon base oils and a superior balanced additive system to provide significantly higher levels of performance above conventional fluids. This unique, advanced technology provides long drain capability, excellent friction retention, and low-temperature fluidity. Further, it helps to improve overall transmission durability and cleanliness. Mobil 1 Synthetic ATF is also compatible with conventional ATFs.
Mobil 1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles.
Approved for Allison C-4 applications
Exceeds JASO 1-A performance standard
Also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363)
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
* Not recommend for CVT applications, Mercon® SP, Ford Type F
** Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and improved performance in 2005 and earlier vehicles, wherever DEXRON is specified
I have been using mobil one ATF for 10 years now in my power steering and no problems and I have 234,000 miles on the car I also use the mobil one ATF in my trans and 75-90 mobil in the rear drive and 5-30 extended mobil one in the engine and change it at 15,000 miles and the car runs great I drain my ps unit every 25k and trans at 25k and rearend at 30k
Old 01-30-10, 03:10 AM
Thermactor
Thermactor's Avatar
toyota t-iv is blended by mobil. its other trade name is mobil 3309
Old 01-30-10, 05:20 AM
python
python's Avatar
cracks me up everytime i hear someone swearing by mobile-1. mobile-1 is the fram of the oil industry, great on advertisement but not the best product.
Old 01-30-10, 09:31 AM
Thermactor
Thermactor's Avatar
Really? Then who's the Donaldson or Baldwin of the passenger car motor oil industry? Don't say it's Amzoil. This should be good.
Old 01-30-10, 03:42 PM
Bippu147
Bippu147's Avatar
I would say Motul
Old 01-30-10, 07:53 PM
no1gsxr
no1gsxr's Avatar
I use Motul 300v in my sportbike. My mechanic took off the valve cover and said everything longs brand new. Very expensive though.
Old 01-31-10, 12:27 AM
Bippu147
Bippu147's Avatar
i use 300V in all my cars. 15w50 summer, 5w40 winter.
Michael
13
11-24-13 08:59 PM
artbuc
RX - 1st Gen (1999-2003)
10-16-12 02:23 AM
jubay
Performance & Maintenance
03-01-10 01:07 AM
Mike
12-09-07 11:23 PM
Quick Reply: ps fluid question (type)
