Someone with service manual please help!
Old 12-31-09, 09:39 AM
Tyke
Tyke's Avatar
Default Someone with service manual please help!
Im removing rack and pinion, got everythign disconnected but I cant take it off...i cant find any space to squeeze it out... the cross member is in the way, the one that holds up the motor..
I need to know if service manual says to remove/drop cross member and engine to take it off, please let me kno ASAP my car is in pieces!
Thanks ina dvance!
Old 12-31-09, 09:46 AM
LiCelsior
Retired
LiCelsior's Avatar
would help to provide year of your car..
Old 12-31-09, 10:01 AM
Tyke
Tyke's Avatar
sorry 1993 LS400
Old 12-31-09, 12:21 PM
deanshark
deanshark's Avatar
Hey Tyke, I'm looking at my manual for the '93 and it doesn't say anything about any crossmembers, as a matter of fact, it doesn't say much at all. Which suprises me b/c this manual is so detail oriented. Better than any other manual I've ever used.
Anyway, if the crossmember is in the way then you're gonna have to remove it or at least loosen it so you have a little more room. Good luck with it.
Old 12-31-09, 02:50 PM
Tyke
Tyke's Avatar
Thanks for trying..
Well I decided to stop being lazy and just drop the cross member....now Im going to swap my motor mounts while im in there...they are right there...
If anyone wants to do this (swap the rack) you will need to drop the cross memeber, no other way around it....just get a jack right under the oil pan, but a thick board between the jack and the pan, and lift the motor a tini bit...
then disconnect Lower Control Arms, then remove 6 screws under (2 are for the motor mounts) and it will drop..then you will have enough space to have a party
Not lookign forward to putting everythign back together though, working on the floor with this is a real PITA...
Old 12-31-09, 04:40 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
uhh its been a while but iirc for the UCFxx chassis all you need to do is disconnect the tie rods, steering column, ps hoses, wiring, remove the steering rack bushings, and the last couple attachment points, then SLIDE the entire rack over to the passenger side, drop the driver's side down, then pull it out.
but i'll check my manual tomorrow or the day after.
Old 01-01-10, 08:20 AM
deanshark
deanshark's Avatar
That's pretty much what the manual says except sliding it to the passenger side. Then it shows ya how to rebuild it. Doesn't look too hard to me, but I would just buy the new one just to save time.
Mtdave2
08-18-14 10:46 PM
kmoore737
SC- 1st Gen (1992-2000)
11-04-12 03:52 AM
Lendaddy
GX - 1st Gen (2004-2009)
10-19-11 07:26 PM
twylie
08-13-09 09:28 AM
djkevin510
Performance & Maintenance
05-08-08 09:29 PM
Quick Reply: Someone with service manual please help!
