sunroof (leaking)
Old 09-23-09, 12:08 PM
mirz833
mirz833's Avatar
Default sunroof (leaking)
My sunroof leaks even when its closed all the way and i dont no where to start. Do sunroofs have like a litle hose that like goes under your headliner to take the water out like a drain pipe if so do i just thave to clean or replacet it or do they have a ruber seal that goes around sunroof that goes bad. Can someone help me understand the whole workings of a sunroof.Thank you guys for help
Old 09-25-09, 03:46 PM
KilaWombat
KilaWombat's Avatar
I had this problem on a 93 LS before. There are drain holes (if you open the sunroof, you can see them). You can blow air through the holes with an air compressor. After I cleared them, there was no more leaking!
Old 09-26-09, 01:41 PM
Twix
Twix's Avatar
Confirmed...
I had the same issue, and went to a company that "fixes" sunroofs, and the guy told me that the factory sunroof never leaks, only the water drain holes clouge up...
After cleaning them, no more leaks.
Old 09-27-09, 05:57 PM
gtoden1
gtoden1's Avatar
Hey, I have a LS400 1993 also and I have the same problem with water coming in, the floor behind the driver seat is soaked. Thanks for the advise on taking an air hose and blowing it out.
Old 09-30-09, 08:49 AM
denverdog
denverdog's Avatar
if the sunroof never leaks, where does the water come from that goes down the drain holes?
Old 09-30-09, 01:39 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the seals between the sunroof and the interior dont leak unless there's enough water presure in the channels (caused back backed up water from the clogged drain channels) to overwhelm the seals.
Old 10-01-09, 12:18 AM
Twix
Twix's Avatar
Yeah, another words the rubber around the sunroof cover is only allowing the amout of water that can safely drain down the drain holes...
P.S.Sorry, my English (expressing myself) - sucks
Old 01-15-11, 07:09 AM
gsteege
gsteege's Avatar
Any idea where the drains are located, I do not see them?
Old 01-15-11, 10:33 AM
willhickey
willhickey's Avatar
i think you have to remove the headliner.., mine leaks also i can also push up on my sunroof???? and its missing the seal that seals where it tilts up and down im going to start there
Old 01-15-11, 11:38 AM
gtoden1
gtoden1's Avatar
If you have a weed wacker use the line or go to Lowes and buy some, its great for cleaning out the plastic tubes, there are four of them (two in the front two in the back.
Old 01-15-11, 03:46 PM
Extrudedco
Extrudedco's Avatar
Yup, most sunroofs aren't designed to seal perfectly. The seals keep most of the water out, but drainage systems take care of the rest. When it doesn't drain, water leaks in.
Helped deal with an F150 that had the rear drainage tray fall off. Naturally, we didn't think much of the occasional drip until we had a couple inches of rain overnight drench the driver's side interior.
Old 05-11-17, 02:26 PM
Mcrosby
Mcrosby's Avatar
Default Leaking sunroof 98LS
So, I was sitting in my Lexus after I had been driving around in the rain, then the overhead main light assembally (where the sunroof control is) started to not just leak, but drain on to the wood grain. Luckily I had a roll of shop towels and used half the roll cleaning up the mess. Do I need to blow out the drain holes, reconnect the drain hose, what do you guys think.
Old 05-11-17, 02:42 PM
dicer
dicer's Avatar
What year etc? Yes clean the drains and probably do my seal fix.
weeb
04-20-14 10:53 AM
boris
10-25-09 12:16 PM
rexus31
23
04-20-09 06:26 PM
spxChrome
03-28-09 12:52 PM
KilaWombat
05-23-06 03:14 PM
Quick Reply: sunroof (leaking)
