Another question on CEL Situation
Quick question...Had the infamous CEL light together with TRAC off light..Pulled a code 28 on the engine which is right main 02 sensor when i tried to pull the code on the TRAC nothing came up..Is 02 situation the only thing to worry about? TIA! (I did search )
Yes, the LS400 ECU generally disengages the traction control (TRAC OFF) whenever a CEL comes on. It will not engage until the problem is resolved.
The 02 sensor replacements aren't very difficult but any mechanic will definitely charge A LOT to have the job done.
Goodluck!
PS:Try searching ebay for a replacement O2 sensor, in order to save yourself some money.
Goodluck!
Thanks CP...I already checked the tutorial to bone up on the swap...Also found Denso universal 4 wire o2 sensors (#2344000) on Rockauto.com for $48.99 each..or $80.79 per for direct fit..
Well, if im not mistaken, there are a few threads here (PLEASE SEARCH :-P) that will definitely aid in the replacement of the sensors. From my understanding, pre-cat o2 sensors are the ones that can cause harm, versus the post-cat 02s, which have little to no effect... I think.... lol
Anyway, look it up, get it done and get the car back on the road
