Radio Problem
Old 05-07-09, 02:02 PM
Sid Ellner
Sid Ellner's Avatar
Default Radio Problem
I have a 93 LS400. The battery was changed recently and now the radio produces no sound. I am able to see the display, can change stations, switch from Radio to CD etc., but no sound. All suggestions welcome.
Old 05-08-09, 04:24 PM
qewani1
qewani1's Avatar
was it working fine before changing the battery?
Old 05-08-09, 08:05 PM
Do.Man
Do.Man's Avatar
check fuses first. then test speakers. last is to check the amp.
Old 05-10-09, 01:41 AM
mista808
mista808's Avatar
i had a sorta similar problem.. i tried to start my car and nothing happened, battery died, then i heard a pop. changed out the battery with a new one, and now my radio wont turn up past 1/4 way.... anything past 1/4 the highs and mids will cut out and i can only hear the woofer... my best guess is a blown resistor inside the head unit... sound system is pioneer, only amp is for the woofer, the door speakers is powered through the head unit. if u have nakamichi (sp?), all speakers are powered by external amps... maybe check fuses to the amps........?
Hiep25
ES - 5th Gen (2007-2012)
03-12-18 05:58 AM
Smallworld
04-10-13 04:26 PM
rome99LS
06-22-12 03:50 PM
RUSSOM
12-01-11 11:30 AM
Quick Reply: Radio Problem
