Timing belt service parts list!
Hi guys..I just got a 1996 ls400 with 160k miles..since this is a interference engine..I don't want to riskly on this baby..well..I am planning to do the whole timing/water pump jobs..can someone list the parts that need to be replace..like any pulleys? seals? oil seal? etc...I did a job on the camry..but this is a big v8..I don't want to mess up anything or missing out something..thanks very much!
My DIY list (
Timing belt
13503-0f010 Timing Idler Left
13505-50022 Timing Idler Right
Water pipe o-ring
Shipping
16100-50022 Water Pump
Muliti rib belt
90311-A0001 Front Crank Seal
Silicone adhesives
Timing belt
Water pipe o-ring
Shipping
Muliti rib belt
Silicone adhesives
Hey guys..this seem to be a very good deal..anyone buy from this seller before? claim to be all OEM parts..is it true? thanks
http://cgi.ebay.com/ebaymotors/89-97...1%7C240%3A1318
The pictured items are not in Toyota/Lexus packaging. Are they really OEM parts? Who knows?? Ad does state that for new water pump as opposed to reman, add $100. New Lexus water pumps are available for $105 from websites like mylexparts.com, so I don't know how good of a deal you are getting. Plus, it only lists one idler pulley; engine has two.
Hi guys..I couldnt believe it..I got quote from the local stealer for the timing belt kits is $700.17 + tax =763.19 (normal stuffs that they uses for the customers when they do the timing belt service) the tensioner for the drive belt is 274.35 + tax but would have to be special ordered...just the parts...labor not included..:-)))
The cost of my list above: all from Autopartsworld except timing belt from Maplewood Lexus. Shipping free above $75 and I used 2nd day.
$74.54
$29.93
$50.77
$2.61
$4.00
$109.58
$27.57
$7.98
$10.00
$6.86
Total $323.84
Timing belt
Water pipe o-ring
Shipping
Muliti rib belt
Silicone adhesives
$74.54
$29.93
$50.77
$2.61
$4.00
$109.58
$27.57
$7.98
$10.00
$6.86
Total $323.84
Timing belt
Water pipe o-ring
Shipping
Muliti rib belt
Silicone adhesives
For many folks here the TB maintenance is a good time to replace not only all of the pulleys & tensioners on the TB assembly but on the Accessory Belt as well.
TB +
Tensioner Part #
Ider Bearing Left Part #
Idler Bearing Right Part#
Accessory/Serpentine Belt
Tensioner Part #
Pulley # 1 Part #
Pulley # 2 Part #
On one of these 2 Serpentine Belt pulleys I replaced the bearing only with a non Toyota part # NTN 63011LL
The part #'s I have are suspect & I do not wish to add to anyones confusion so if anyone can clear up the part #'s for a 1st gen. It would be appreciated!
Last time I went thru it I also got into the alternator:
Note: All #'s below are accurate for 90-94 LS Models.
Alternator Parts
90099-10192 Front Alt. Bearing
90099-10194 Rear Alt. Bearing
27370-75060 Brush & Holder
Front Cover Gasket
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
90311-38036 Cam seals ( 2 Total )
94 LS with 206,516
TB +
Tensioner Part #
Tensioner Part #
Pulley # 1 Part #
Pulley # 2 Part #
Alternator Parts
Front Cover Gasket
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
94 LS with 206,516
TB +
Tensioner Part # 13540-50030
Idler Bearing #1, left lower (13505-50022) / Koyo part # B7553-KOY-A5300
Idler Bearing #2, right (13503-0F010) has "ear" attachment / NSK part # C7553-NSK-A5300
V-Rib Tensioner Part #16620-0W035
Pulley w groove Part #16604-0F010 * / Gates #36026
Pulley smooth Part #16603-50010 *
Serpentine Belt pulley #16604-0F010, I replaced the bearing only with a non Toyota part # NTN 63011LL
* Has been noted on the CL Forum that McMaster-Carr bearings #5972K44 & 5972K86 are bearing only alternatives for those with access to a shop press.
Would very much like to double check all the above for accuracy. Please correct any mistake as I will not be offended.
This was for my 94 LS400
Nice post Nthach!
Idlers & pulleys was the most confusing part of the order for me so that is the portion of a TB change I was trying to clear up.
I will say this though - you can find the smaller bearings for the serpentine drive system at Grainger or other industrial supply houses. You can search the local parts houses for the timing idlers - you're looking for NTN, Koyo, NSK, or ***(its a German bearing brand). Gates, Dayco, and Beck-Arnley are aftermarket suppliers that rebox.
