1996 LS400 Stalls after prolonged use of cruise control
Old 12-30-08, 08:39 PM
gvm
gvm's Avatar
Default 1996 LS400 Stalls after prolonged use of cruise control
I have read a number of posts about this problem but as yet, there seems to be little certainty about the cause of the problem. I've just been on a driving holiday and so have more information that might help diagnose the problem.
The problem is that, after cruise control has been in use for prolonged periods, eg 1 hour, at high speeds, eg 100 -110 kmph, the engine sometimes stalls when the speed drops to around 40kmph or 25 mph. (40 kmph is the lowest speed at which cruise control will normally operate but this fact might be sheer coincidence).
The new information I have is that the engine stalled even if cruise control is switched off prior to dropping the car's speed to the vicinity of 40kmph.
Previous posts have suggested the problem is caused by a faulty control computer, poor or blocked ventilation, an intermittent control motor. Can I have your opinions please? TIA ... Greg
Old 12-31-08, 12:27 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
ECU issue, replace.
Old 12-31-08, 02:35 AM
PK_Celsior
PK_Celsior's Avatar
Originally Posted by PureDrifter
ECU issue, replace.
+1 i had to change out the ECU on my 95 beacuse of this problem.
Old 12-31-08, 07:31 PM
gvm
gvm's Avatar
Default supply of replacement ECU
Thanks for the replies. A replacement part appears available from
http://cgi.ebay.com/ebaymotors/LEXUS...71510005r25736
Can I be confident that purchasing from here will be safe and provide the correct part for my 1996, right hand drive, Australian car?
regards
Greg
Old 01-01-09, 05:55 PM
hobojoe
hobojoe's Avatar
Maybe now would be the time to upgrade to Say a Mines?
Old 01-02-09, 01:06 AM
gvm
gvm's Avatar
Maybe hobojoe; but what do people think about my question....
regards
Greg
Old 10-25-10, 10:04 PM
Scaritto
Scaritto's Avatar
Sorry to bring up an old thread, but my 95 is doing this too. Can someone tell me where i can locate the ecu and where i can purchase one?
Old 10-26-10, 06:29 AM
jrbump
jrbump's Avatar
I would try searching "LS400 ECU" on ebay, but that's just me.
Old 10-26-10, 11:21 AM
PureDrifter
BahHumBug
if you search harder you can find the right part number to compare to.
Old 10-26-10, 06:49 PM
Scaritto
Scaritto's Avatar
I know where that large list is of part numbers is, i just don't know where the ecu is located in my car to find the part number of mine
Old 10-26-10, 08:18 PM
gvm
gvm's Avatar
Default ecu location
It's a while since I went looking for mine but I'm pretty sure it was located above the accelerator pedal. Please let us know if the new ECU fixes it; I'm still living with the problem TIA.
FYI, there is also detailed information at this Australian LS400 forum,
http://au.lexusownersclub.com/forums...=1&#entry16046
cheers ... Greg
Old 10-27-10, 04:58 PM
Scaritto
Scaritto's Avatar
Aww thank you!
CDeLappe
02-11-17 11:17 PM
Gtidan
02-04-10 09:08 PM
09RX350AWD
01-14-10 03:31 AM
draco
05-24-09 06:54 AM
Quick Reply: 1996 LS400 Stalls after prolonged use of cruise control
