Front Seat Belts Problem on 95 LS400
Old 11-02-08, 10:33 AM
Salil022
Salil022's Avatar
Default Front Seat Belts Problem on 95 LS400
Guys
Just bought a 95 LS400 with 139xxx miles...Both front seat belts have retracting problem...It won't go back into the track...Belts seems all loose, not sure what the problem is...Any suggestions on how to fix it?
Old 11-03-08, 07:29 AM
Salil022
Salil022's Avatar
No one else is having loose seat belt problem??
Old 11-03-08, 08:04 AM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
New belt assembly.
I've seen it before on other aged Toyota's...it wears out with use. By then, the belt is fraying too. Safety first, replace it.
There was a recall/safety check on the tensioners. Both mine ('97) were replaced in the car's early history like sub 10K miles.
Old 11-03-08, 10:41 AM
Salil022
Salil022's Avatar
Seems like i am going to have to install new seat belts assembly on both sides!!
Old 11-03-08, 12:02 PM
steveski
steveski's Avatar
Yes unfortunately you must install new ones. I am having the same issue on my 95 on both front seats.
Old 11-04-08, 05:49 AM
python
python's Avatar
call lexus customer support 1-800-255-3987...they will give u instructions
Old 11-05-08, 05:25 PM
adorjr
adorjr's Avatar
Default Seat Belts/Lexus Customer Service
Yup. Call Lexus Customer Service about the seat belts. They will give you instructions on what you can do to have the seat belts replaced. Use Search-- this has been discussed previously in the forum.
Old 06-05-24, 02:07 PM
Elliot2008
8th Gear
Elliot2008's Avatar
I Can't find a replacement for the driver side. Would a passenger side seat belt assembly work?
Old 06-05-24, 03:55 PM
CELSI0R
CELSI0R's Avatar
No. The passenger side assembly is different.
You can have your belt rebuilt by services online if you can't find a used one, or maybe you can try cleaning it first
An example of a rebuild service (may not be applicable if you don't need the pretensioner replaced. You may need the retractor repaired)
https://www.safetyrestore.com/seat-b...lt-repair.html
Old 06-05-24, 04:35 PM
Elliot2008
8th Gear
Elliot2008's Avatar
https://www.youtube.com/watch?v=6n2_vEmQwQI
The repair link you sent me is a different thing, for some reason I get a bunch of different things when I search up the seatbelt assembly. I have a link for the passenger seatbelt. But I can't find the driver side
https://www.ebay.com/itm/22601476264...xoCxyUQAvD_BwE
Old 06-05-24, 05:23 PM
paulo57509
paulo57509's Avatar
You're probably having trouble finding a driver side belt assembly because most of them are already FUBAR because they're the most used.
The Safety Restore link works for me.
Old 06-05-24, 05:35 PM
Elliot2008
8th Gear
Elliot2008's Avatar
The safety restore link works for the assembly in the link I sent? Even though it looks different?
Old 06-05-24, 07:25 PM
CELSI0R
CELSI0R's Avatar
I would recommend cleaning your seatbelt first, and see how that goes..
The Safety Restore link should be for a general repair service. I sent that one because I don't know what's bad with your unit
I should note however, that link may not be the solution for you
You may just need the retractor repaired / rebuilt. Probably worth searching online
I'll update my post to reflect this more accurately
Old 06-06-24, 11:09 AM
paulo57509
paulo57509's Avatar
I don't understand the question. The link you posted previously is for an ebay listing. Not for Safety Restore.
geoprz
12
04-18-14 08:44 PM
krawfo
07-21-11 07:55 PM
Dex334
05-18-11 11:43 PM
chadr
25
08-05-09 08:24 PM
Brian Zado
02-09-07 05:12 PM
Quick Reply: Front Seat Belts Problem on 95 LS400
