Rear braking problem...
Old 10-08-08, 08:13 PM
RandomHero
RandomHero's Avatar
Default Rear braking problem...
So, funniest thing when I'm braking in my 93 LS 400...
When braking, the rear end shifts to the right (somewhat violently), almost seems as though one caliper in the rear is working.
However, I took a look at the brakes today and everything seems to be on right, the pads are still good, rotors look good, lines look good, etc.
Anyone experience this before? I'm stumped!
Old 10-08-08, 08:25 PM
hobojoe
hobojoe's Avatar
Just an idea the guy i work with his work truck an older Tundra like a 02 did this. he tried turning the rotors replacing the pads, machining the rotors turned out to be a bad gasket was leaking diff fluid onto the rotors somehow.
Old 10-08-08, 08:41 PM
trukn1
NELOC Mod
trukn1's Avatar
My 92 used to do this when I first got it (Mine used to jerk hard to the left). Turns out that I had REALLY BAD bushings in the rear end. Check the ones in the Carrier Arm, as these were my culprit. Changed them,, no more rear end dance.
Old 10-09-08, 02:47 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
check bushings and rear diff mounts.
azipod
10-23-18 07:15 PM
tangcoral
15
06-05-08 12:56 AM
Grier
Suspension and Brakes
05-04-07 07:09 PM
mobilyte
09-16-06 11:55 PM
rclab1
09-01-06 11:47 AM
Quick Reply: Rear braking problem...
