Need help. 91 Ls400
Old 09-25-08, 01:28 AM
raginazn
raginazn's Avatar
Default Need help. 91 Ls400
Problem started today when i took out the air filter for an inspection.
Looked fine to what i could see. Decided to clean the maf. Let it dry for about 2 hours. When i went to start the car, it started ran fine for about 2 seconds and then went into a roller coaster motion in rpms. would idle at around 800 then drop down to almost 0, the engine would not die but instead kick itself back up to 800 and repeated this until i manually shut the car off myself.
My question is why.
Why would it do this?
What could be a fix?
I have done a search, and i have read that cleaning the maf could be bad....(wish i would of read it before) but i havent seen anyone getting the same problem as i have. Looking for input. Please help
Old 09-25-08, 08:43 AM
19psi
19psi's Avatar
there's really no point in cleaning the 91 style maf's. what did you spray in it?
give it some time to dry up. you plugged it back in when you reinstalled it right?
Old 09-25-08, 08:52 AM
trukn1
NELOC Mod
trukn1's Avatar
MAF sensors are SUPER SENSITIVE to cleaning. Most of the time not really worth it unless it is acting up. Allow more time for it to throughly dry,, pretty much think you are gonna need a new MAF though.
19-- where in Louisville are you located? I work for Summitt trucking based in Clarksville, IN. right across the bridge on 65? Am in/nar/thru KY on a regular basis.
Old 09-25-08, 01:39 PM
19psi
19psi's Avatar
i'm in louisville.
1302L
09-06-17 12:12 AM
1302L
09-05-17 11:56 PM
ccb_v2
04-27-09 08:19 AM
mikewu
01-12-08 10:02 PM
varcity64
07-07-06 09:25 AM
Quick Reply: Need help. 91 Ls400
