Mobil 1 Mercon V Multi vehicle ATF?
Old 10-13-08, 04:12 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by python
lmao......i used valvaline dexron/mercon 3 when i had my tranny flushed...works fine
as long as u dont use ford or chrysler types u will be fine
Goodluck after a few thousand miles, you will need it from personal experience.
Ford uses mercon by the way.
Old 10-14-08, 06:39 AM
python
python's Avatar
been 12,000 miles already, what problems did u experience?
Old 10-14-08, 06:44 AM
python
python's Avatar
i will call valvoline today and ask the rep if its compatible,i will answer back today or tomorrow with a definitive answer, i think i would trust a tech from valveline to recommend the correct fluid as thats what we sell at NAPA
Old 10-14-08, 07:08 AM
python
python's Avatar
just called them 1-800-832-6825 ext.#5
part number "324" maxlife covers type t-iv toyota fluid
Old 10-14-08, 07:55 AM
python
python's Avatar
also did some more research, adding that lube guard #61910 is what u use to make dexron3 compatible with t-iv so everything thats been posted by u guys is correct, i will add this stuff today....thanks
Old 10-14-08, 12:12 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
next flush i'd use T-IV...
Lube-Guard's site says that by adding the modifier, normal Dexron/Mercon fluid can fill in for all of the following.
Mopar ATF + 3/4 = Genuine Honda = Toyota Type T & T4 fluids.
which we know is very much NOT TRUE since each type has specific properties....
http://www.lubegard.com/automotive/trans_atf_hfm.html
Old 10-14-08, 04:55 PM
python
python's Avatar
ok heres the deal....in 1992 type t-iv was not even around, type t-2 was used, so me having a 92 Ls 400 using the fluid i have will not harm it
Old 10-14-08, 04:59 PM
python
python's Avatar
also u might want to read the lubegaurd site a little more thoroughly PD....it says: LUBEGARD® Highly Friction Modified-ATF Supplement converts DEXRON II,III/MERCON ATF into a highly friction modified fluid. And at the same time extends your fluid life and reduces your transmission wear, saving you money and the need to stock multiple OEM fluids
Old 10-14-08, 05:01 PM
python
python's Avatar
also the honda type Z was not around and they insist on using it in older hondas as well...call your local trans shop and ask them, i work at NAPA and get my information first hand
Old 10-14-08, 07:34 PM
PureDrifter
BahHumBug
you are right, it used to be Type T-II, which was REPLACED by T-IV. go to your dealer and say you want toyota T-II and they'll hand you a box of T-IV. there's even TSB's out for every model that was using "T-II" stating as such.
try to find T-II.
i said that all those "modified" fluids they listed are not equivalent to eachother, so how can one fluid (modified Mercon with ONE single additive) fulfill all their requirements.
Old 10-15-08, 06:17 AM
python
python's Avatar
it adds friction modifier which is the only thing u need to be concerned with...no biggie bro, i dont want to get into some debate here, i talk to owners of shops who have years and years of experience of automotive service, if they were to ruin their customers cars because of negligence...they would be out of business, not to mention they have mitchell on demand at their finger tips....when it comes right down to it, your are correct in everything u say, but the lube guard will do its job as a supplement
Old 10-15-08, 07:07 AM
ravls400
ravls400's Avatar
Does any body know where you can get the T-IV online for $5-6? My local dealer is selling them for $12 a quart.
Thanks
Old 10-15-08, 07:44 AM
python
python's Avatar
what year is your LS?
Old 10-15-08, 07:50 AM
ravls400
ravls400's Avatar
1990 just found a dealer who wants $4.75 a quart
Old 10-15-08, 08:27 AM
python
python's Avatar
thats not much higher than reg atf is goin for! stock up
Quick Reply: Mobil 1 Mercon V Multi vehicle ATF?
