96 Parking Brake Adjustment
Old 04-22-08, 11:51 AM
JBrewster
JBrewster's Avatar
Default 96 Parking Brake Adjustment
I'm trying to remove my rear rotors and they just won't come off. They wiggle a bit and one side of the rotor is looser than the other, so it leads me to believe that the parking brake won't disengage fully.
I've been searching the forums but I just can't seem to find the correct procedure for adjusting the parking brake. I followed the wire back to just in front of the differential and tried loosening it but it doesn't seem to be working.
Is there an adjuster on the hub through the hole in the rotor?
Old 04-22-08, 02:27 PM
nickhere
nickhere's Avatar
Mine is a 92 and there is a rubber plug about dime size on the outboard side of the hub. Pull the plug and there is a star adjuster inside at 6 o clock. I believe I read another thread at another site that the 2nd gens were the same.
Old 04-22-08, 05:51 PM
JBrewster
JBrewster's Avatar
I'm familiar with the star adjuster but I didn't see it. I'll look again though, maybe I didn't look down.
Old 04-23-08, 07:37 AM
JBrewster
JBrewster's Avatar
Whoever put the rotors on last didn't align the hole with the adjustment wheel.
Old 04-23-08, 12:01 PM
DIY LS400
DIY LS400's Avatar
Did you try hitting it out with a hammer or screwing in a bolt through one of the holes against the hub to push the rotor out?
Old 04-23-08, 01:44 PM
JBrewster
JBrewster's Avatar
I ended up getting it off with a wheel puller. Hammer wasn't doing the job. I still have to do the passenger side.
I seem to have broken the parking brake though... the rear side is very loose.
CPMD
03-27-23 04:27 PM
95rover
GX - 1st Gen (2003-2009)
07-28-18 08:56 PM
trhs75
RX - 1st Gen (1999-2003)
09-21-09 08:46 AM
mjr24
Wheels, Tires & Brakes Forum
09-12-03 08:14 AM
silver01gs
Maintenance
08-21-03 12:49 AM
Quick Reply: 96 Parking Brake Adjustment
